Buying a used G35-What to look for?
Old May 15, 2010 | 08:33 PM
2hard2fixagain's Avatar
I am getting a 2003 G35 Coupe soon, its got 104k miles on it and needs some TLC, but I am getting the (clear titled) car for $5500
I know basicly what to look for-oil leaks, noises, trans fluid, just regular common things to go out/bad, but what are these vehicles prone to having problems with?
Thanks in advance
Old May 15, 2010 | 09:06 PM
cpufreak3's Avatar
Seems too good to be true. Have you seen the car in person?
Old May 15, 2010 | 09:30 PM
dias724's Avatar
^^^ agreed...
Old May 15, 2010 | 10:07 PM
TootsieRoll7's Avatar
I sold a 90 200k+ miles Toyota Celia for $2500. Something is wrong with that price. Check to make sure it wasn't in any accident. Check the windows and windshields for melt dots caused by spark from grinding. Check to make sure the numbers on the glass match. If they don't they have been replaced from either accident or break in. That's what the guy who did my tint told me. Can someone with body shop experience confirm that?
I wasn't happy to find out my car was hit and the dealer didn't tell me. Hope that help.
Old May 16, 2010 | 12:41 AM
gck's Avatar
gck
dude .. the cd unit....windows...just check the wholleeeee car run it for a while..look iut for weird noises.
Old May 16, 2010 | 01:56 AM
The original asking price was $8,000. Which sounded reasonable. He had it for sale for awhile and I was really the only one interested in it. I saw it briefly and he said if I can get it by the end of the month its $5500. It needs new fenders, mirrors, and some body work to the passengers side (a 6'' oval dent). Tires are bald as well.
I have seen it, briefly. I will look over the entire car, thats a good idea about the windows. Thanks.
I am going to do a compression test on it as well, and run a carfax.
Old May 16, 2010 | 02:31 AM
VxLyf3's Avatar
that cheap...get a tech to go with u..
Old May 16, 2010 | 10:37 AM
G_JaY-SInGH's Avatar
that's a good deal.
now just find a mechanic...
Old May 16, 2010 | 03:47 PM
I am a Chrysler/ASE certified mechanic, in a few areas.
I was just asking about specific little things that these cars are prone to. Examples: Oil consumption, the small leak sometimes present by the 6th cylinder coil pack frm the valve cover, etc. I don't know alot about this specific model of car and where the weaknesses are.
Old May 16, 2010 | 07:38 PM
bocatrip's Avatar
If it's a manual, check the trans as most have issues. Automatics are bulletproof. Other than that, check the usual....tires ,compression rods, window motors, actuators, cd changer. Most can be fixed reasonably. Trans and engine oil consumption are biggest and most expensive issues. Good luck. The price is right.
Old May 16, 2010 | 09:01 PM
G35,6MT's Avatar
how do you check the trany, other than driving it?
Old May 17, 2010 | 01:06 AM
I will check the trans fluid and make sure tis clean(ish) and that theres no shavings in it. I'll put it in the manual mode as well and make sure it shifts smoothly in both modes.
If it uses oil i'll probabally just go a different route on modifications with the little extra money I have. I planned to get the whole car painted a diffrent color, but if need be I can get it rebuilt and boosted and just get the body panels that need to be fixed painted the original silver color, which I wouldn't mind a bit.
Old May 5, 2011 | 01:53 AM
vashuba311's Avatar
i looked at an 05 6mt coupe today. it didnt pass the dealers inspection due to a broken flex pipe. Need new tires. They claimed the engine was damp around the oil pan. Is a product of the oil consumption issue? I going to test drive it friday when i have time.
The intake front feed tube thing was missing Im assuming it was modded somehow? but not really sure
Old May 5, 2011 | 02:06 AM
truongxlong's Avatar
check your a/c when i bought my car that's one thing that didnt really occur to me and I ended up having to replace my A/C run your A/C and see if it affects your belts cuz sometimes mine squeeks on start up. check for camber wear on your wheels and suspension. and check if it has the right spare tire just incase. They gave me a small little 16" spare tire that doesn't even clear brembos still riding spareless. deal sounds too good to be true
blnewt
Sep 25, 2015 01:48 PM
Jpete
Sep 25, 2015 01:38 PM
Dannyy06
Sep 25, 2015 11:32 AM
mamba24
Sep 15, 2015 10:37 PM
twentyeggs
Sep 11, 2015 03:58 PM
