Does This Sound Right - Tire Size?
Old May 22, 2010 | 08:21 PM
sierrahpbt's Avatar
'04 G35 Coup w/ Sport Pkg. I want to increase the width of my rear tires when I replace them. My local tire dealer told me I could upsize from 245x45-18 to 275x40-18 on my stock rear rims with no problem and that the diameter would change very little from stock. The Miata tire calculator seems to support this..but I haven't found a thread that supports this. I still have 225x45-18 fronts which do not need replacing anytime soon. Any advice?
BTW, I spent about two hours searching threads. If I have missed one that address this please let me know.
Old May 22, 2010 | 08:39 PM
NachoCheese's Avatar
You'll be fine. The lower sidewall rating with the wider tire will make sure your VDC doesn't go crazy
Old May 22, 2010 | 08:44 PM
gary c's Avatar
I don't think that sounds right for an 8" rim since I'm running 275s on a 10" rim and it's like perfect. I wouldn't go any larger than 255/40ZR18, there's no real advantage of going that wide on your rims. Looks, I doubt when installed you could tell the difference between the two except with the 275s you might have tire buldge....not good! When you need to replace the fronts you could easily go with 245/40ZR18s for far better control. I dislike Nissan's idea of using that small a tire on the front end where 52% of the weight is....my .02cents.
Gary
Old May 23, 2010 | 08:32 AM
sierrahpbt's Avatar
Thanks for the advice. This really gets confusing for a tire novice like me. Anyone running the steup I'm talking about? I'm just looking for a wider rear tire without problems.
Old May 23, 2010 | 11:31 PM
Dante's Avatar
I would run 255 on the rear, anything higher than that is just not worth doing...
Old May 24, 2010 | 10:59 AM
G35Lopez's Avatar
275 will help avoid curb rash. My .02 cents.
Old May 24, 2010 | 12:10 PM
G35fromPA's Avatar
I wouldn't run a 275 tire on an 8" wide wheel. Too much center bulge could lead to accelerated center wear and possible poor handling or VDC problems. Recommended rim width for a 275 tire is 9-11"
Old May 26, 2010 | 03:24 PM
Dante's Avatar
I have 295 with an 11"
works for me....
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
