Engine Problems? Concerned G Owner
Old Jul 23, 2010 | 08:50 PM
DT35G's Avatar
Okay, so i noticed every now and then when I first start my car I get these weird almost clunking noises. It lasts only a couple seconds and then its gone. When I hear it, it scares the the G right out of me. Anybody else? What is it? My car runs and drives fine, its just occasionaly on start up.
Old Jul 23, 2010 | 11:37 PM
REVUPG35's Avatar
my car does the same exact thing! ??? I was thinking of taking it back to the dealer for oil consumption issue... Maybe that is what is causing that noise mostly when its cold right...?
Old Jul 23, 2010 | 11:38 PM
jibberjabbers's Avatar
Your engine is f'd most likely.
Another member had the same problem. Some said it was "normal" start up noise. Some said it was just the ABS kicking in... Turned out, he needed a new motor.
Video is attached in this link.
https://g35driver.com/forums/engine-...upe-video.html
Old Jul 23, 2010 | 11:46 PM
RiversideS13's Avatar
is it common on all G35?
Old Jul 24, 2010 | 10:22 AM
DT35G's Avatar
I dont know, its not every cold start, just occasionlly. I have no fkin warrantly so im gonna be sol if my engine goes.
Old Jul 24, 2010 | 10:46 AM
gary c's Avatar
My car makes a noise that I contributed to the ABS waking up on occasional cold starts. She doesn't use any oil and that's the only time I hear any unusual noises.....runs great too.
Gary
Old Jul 24, 2010 | 11:37 AM
DT35G's Avatar
Yea, mine too. It runs great, only notice it on occasional cold starts. Just checked the oil, after 2000 miles not loosing any and is crystal clear. I use synthetic and its as clear as it was when i put it in.
Old Jul 24, 2010 | 03:03 PM
nchi's Avatar
i think this is the abs it happens to me all the time buts its not loud clunking noise its a grinding noise n you feel it @ the pedal
Old Jul 24, 2010 | 03:56 PM
From the link I posted.. The Tech at Infiniti "discovered the problem by accident"... The car did not always make the clunking noise. It only happened here and there and usually on cold starts.
They replaced the valve cover due to the OIL on the plugs. When they removed the valve cover, the tech discovered the damage and metal shavings all over...
So that's probably the only way to find out if your motor is still good. Either pull the valve cover off or remove the oil pan to see if there are any metal shavings.
Again, people all claimed it was "normal" in that thread. So better safe than sorry. Get it checked.
Old Jul 24, 2010 | 04:03 PM
Lone Wolf's Avatar
Thats the ABS
Old Nov 2, 2010 | 11:00 PM
SlickGPA's Avatar
just got this in mine. went out a few days ago started her up and BANG BANG BANG....loud as hell for the first 30 seconds...idled rough.....then went away after warmed up....WTF? only 500 miles on a fresh oil change....oil level topped off and fine....running the same 10W 30 Mobil 1 Synth for the past 40k miles.....i thought the motor was blown......now i'm scared to even start it....
Old Nov 3, 2010 | 10:38 AM
DT35G's Avatar
Mine wasnt that loud but still scared me. I moved up to NY and havent heard it at all since i left florida. Maybe it had something to do with the heat and hummidity???? Either way, still running strong!
andyg35c1
Aug 29, 2015 03:37 PM
derres
Aug 28, 2015 03:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
chinee
Aug 8, 2015 10:11 AM
wojowojo16
Jul 27, 2015 09:57 AM
