High RPM issue..
Old Sep 24, 2010 | 03:33 PM
changeover's Avatar
High RPM issue..
Hey guys, I cleaned my throttle body probably 3-4 weeks ago and every time I start the car it idles at around 2000-2100 RPM's then goes down after I start driving. Im new to these cars so I just was not sure if this was normal or not and no I did not disconnect any wires or anything when I cleaned the TB. Thanks!
Old Sep 24, 2010 | 03:36 PM
develop1's Avatar
My '06 idles between 1000-1500 and slowly goes down to 1000.
Old Sep 24, 2010 | 03:47 PM
jardoeli's Avatar
Cold IDLE is around 1500
Warm IDLE is 500-550
1000 is high for a warm Idle......
Old Sep 24, 2010 | 03:48 PM
eNDleSs's Avatar
eh.. my 06 idles at 500-600 rpms smooth.. 900 with the a/c on..
Old Sep 24, 2010 | 04:12 PM
changeover's Avatar
Are those numbers right when you start it up or after awhile? Im talking right when I start up, it doesnt go down till after I start driving then it goes down to around 500 or so
Old Sep 24, 2010 | 04:23 PM
herrschaft's Avatar
Did you ever start you car and let it sit for a few minutes to let the engine warm up, or do you just start and go?
On a cold start my RPM's will be around 1,500, after a minute or two it drops to 500-600.
Old Sep 24, 2010 | 04:25 PM
changeover's Avatar
^ usually let it run for about 30 seconds to 1 minute before I drive
Old Sep 24, 2010 | 04:27 PM
jardoeli's Avatar
Manufacturers say that that 20-30 seconds on hot days is enough
30-60 seconds on cold days (winter)
When cold never push it. You have to start smooth until the engine warms up properly. Then you can have fun!
I never shift above 3k RPM when cold. After 3.5-4k is my norm.
Old Sep 24, 2010 | 04:38 PM
herrschaft's Avatar
Sometimes it takes my car 1.5-2 minutes to get down to 500rpm in the mornings. Let it set for a few minutes and see where it idles.
Old Sep 24, 2010 | 07:42 PM
Silencer_0's Avatar
I just remote start my car while I'm washing up for work, then it's good to go by the time I'm in the car .
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
