How does your 5at shift in manumatic?
Old 05-25-2011, 09:46 PM
superchargedg's Avatar
Grounding kit did nothing for my 03 but the Transgo shift kit sure did.
Old 05-25-2011, 09:59 PM
broke_as_ajoke's Avatar
Originally Posted by 4D05G35
So the pause between 2nd and 1st is normal? I have noticed that if I manually shift from 2nd to 1st (around 15mph or so) then go to accelerate there is a delay of a good 1.5-2 seconds. I usually try to stay in 2nd, but the few times I drop down to 1st I get that annoying pause.
Right.. i know what u are talking about.. To be honest with u.. first gear sucks in the AT (yes i have an AT).
For example if u are in second and u are decreasing the speed more than 5 mph (meaning u are doing about 10 to 15 mph). IMO leave the car in second if u know u want to "get on it" (mean speed) off. I notice the RPM's are high, but the transmission has not caught up to that speed.. that is when u feel the delay.. So leave it in second.. then hit the gas u wont feel as much delay, but the delay is still there because the gear as not "caught" up to the speeds (rpms) that the motor is turning at.
Old 05-25-2011, 10:29 PM
GAU-8's Avatar
Unless you get the shift kit. Then it's spontaneous on each shift. So much so that it breaks tires and necks if you're not ready.
Old 05-25-2011, 10:57 PM
Hotdawwgman's Avatar
Originally Posted by walshtj
+1, I think its less than 5mph is when I usually do it.
20 mph
Old 05-25-2011, 11:21 PM
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by Hotdawwgman
20 mph
Nahh lol if your meaning downshift to 1st at 20 no way it'll pull and jerk bad...its around 5mph
Old 05-25-2011, 11:22 PM
Silencer_0's Avatar
Originally Posted by gau-8
unless you get the shift kit. Then it's spontaneous on each shift. So much so that it breaks tires and necks if you're not ready.
+1 .
Old 05-25-2011, 11:59 PM
4D05G35's Avatar
Spot on. Thank you. Glad its not just my car, its annoying.
Old 05-26-2011, 10:33 AM
I even changed my diff fluid to see if that would take some out the delay out of it.. (its prolly all in my head, but I think .5 seconds of the delay is gone) lol
05-22-2022 09:26 AM
Picture Share
02-04-2018 12:41 PM
RWDguy4238
09-30-2015 12:13 AM
blnewt
09-25-2015 01:48 PM
UndyingDest
Drivetrain
09-07-2015 12:49 AM
Quick Reply: How does your 5at shift in manumatic?
