Electric Problem !! Its killin me .. How do i fix this ?
I dirve an 03 G35 coupe..
When my lights are turned off , the dashboard , radio lights are all on and working... BUT when i go to turn my lights on, the dashboard, radio and no lights on the cockpit are are running/working.
.. is this a fuse problem or an electric problem? Has anyone had this issue before ? and how do you fix ?
Thanks
Thanks
but ya if anyone doesn't knw try to get in touch with one of the many techs that have accounts on here. maybe they could send u in some type of direction
ya i had to read it three times because i thought that right at first.
Apologies for asking an obvious question - have you tried adjusting the dashboard dimmer? Down by your left knee, right next to the trunk opening switch. I will often miss the trunk opener, roll down the dimmer - interior lights go off, just like you describe until I roll the dimmer back up.
BTW, I think what you are saying (with clarifications added) is
"...when i go to turn my lights on, the dashboard (lights) , radio (lights) and no (other) lights..."
If, OTOH, the radio itself doesn't work (no sound comes out) when you turn on your lights, my answer doesn't apply.
same problem
Did this ever get resolved? I have the exact same problem. I have been going through all the forums but I don't see resolution, or even if it was linked to the problem that most people have with the a/c unit and the stereo. My problem is that when the headlights are off everything functions properly; but when I turn on the headlights I lose all dashboard illumination and function (no climate control, no defrost, no stereo controls although it still plays music, can't see the speedometer, etc). I have an '04 coupe.
Any info on this would help. Thanks.
zcherub
08-30-2015 05:04 PM
