Frustrating Rattle Sound Upon Acceleration
Old Mar 17, 2012 | 03:09 PM
nepenthean's Avatar
Hello.
Upon acceleration in any gear I get an intermittent rattle. It mostly occurs in 2nd/3rd. The problem is it does not occur every time I get on the throttle. I took it to the dealer and they replaced the AC compressor, which did diminish it a bit; but it is still there.
It sounds like marbles in a can. Sometimes it is loud; others it is barely noticeable. Anyone have this issue too?
Old Mar 17, 2012 | 05:48 PM
alex526's Avatar
I have the same exact issue. At first I thought it was a heat sheild but its not , id love an answer for this problem as well
Old Mar 17, 2012 | 05:57 PM
luv2drv_myG35's Avatar
Pinging maybe? Are you using regular gas by any chance?
Old Mar 17, 2012 | 06:33 PM
bythabay's Avatar
This issue has been beat to death
have you tried the search function ?
Old Mar 17, 2012 | 06:43 PM
blackout2277's Avatar
I have a rattle that drives me crazy that goes away after about 2500 rpms. Thought it was a heat shield but can't find it
Old Mar 17, 2012 | 07:09 PM
midnighttheg35's Avatar
Sounds like pinging to me. I had the same thing. After two or three full tanks of 94 gas it went away. Make sure your using proper fuel
Old Mar 17, 2012 | 09:48 PM
norcalG's Avatar
Well I have the same problem with my 05 coup in first gear when on the gas and gos away after fist gear sounded like a heat sheled but that was not it so we put the car on my friends rack and and had him run it threw first gear well up in the air and we found that when u put the motor under a load it twists the drive line and exhaust just enuff To make the exhaust hit the diferenchel housing or pumpkin not
Bad just enuff to drive u nuts and make u think the heat sheled is falling off if u grab your exhaust tip right or left an shake it side to side u will feel it hit just barely so far no fix but I have some ideas hope this helps if u have any ?s just ask
Old Mar 18, 2012 | 12:31 AM
juice-g35-coupe's Avatar
what would we search for ???
Old Mar 19, 2012 | 06:24 PM
thepro78's Avatar
how do u get 94 fuel?
Old Mar 19, 2012 | 06:49 PM
dofu's Avatar
20 Year Member
If it sounds like a heat shield, then you guys might want to check for a piece that runs along the muffler going wheel to wheel. It's a metal piece that has a triangular shape if you look at it from the side, and is there strictly for aerodynamics, comes loose and rattles like an annoying heat shield.
Old Mar 19, 2012 | 09:50 PM
The husky's in my city sell 94, idk where else they sell it..
Old Mar 20, 2012 | 01:46 PM
Teelux's Avatar
Just use premium.
Old Mar 20, 2012 | 05:01 PM
my 94 is the same price as other places premium (91) so thats why i use 94
Old Mar 20, 2012 | 05:25 PM
culi's Avatar
+1. I bottom out my car on speed bump once and the exhaust mounting bracket near the transmission broke and rattle like crazy. It took me a while to figure it out. I have the timing change, flush all fluids, and check a bunch of stuff. In the end, it was a $15 welding job that fix the thing.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
