While driving about 20mph you can hear the tires on the road!!!
Old May 7, 2012 | 05:23 PM
  #31
916TownG35's Avatar
maybe its a sweet soft for the speed
Old May 7, 2012 | 05:35 PM
  #32
a471133's Avatar
Make sure lugs are torqued to spec. Costco didn't tighten my right front and it gradually made more and more noise till the wheel almost fell off.
Old May 7, 2012 | 08:48 PM
  #33
dickjack13's Avatar
ttt
just find some stock wheels and see if the noise goes away
Old May 8, 2012 | 12:53 AM
  #34
partyman66's Avatar
Originally Posted by g35OnTrackz
nope,i just hear about 20mph or lower if i stay steady at like 15 i cant hear it ,,,sound like the tires but i may change the bearings,now that u said that
You can usually flush out a wheel bearing problem and isolate it down to that by going into an empty parking lot and doing long sweeper turns in either direction. If you hear a deep groaning noise while you do that in either direction, it's the opposite side wheel bearing (of the direction you're turning) that's worn (the loaded side). So if you turn to the right and you hear the noise, it's your left wheel bearing, and vice-versa.
You can also lift the front end of the car off the ground and test each front wheel bearing for free play separately by grabbing the wheel at 12 and 6 O'clock with your hands and pushing on the outer edge of the tire with one hand (at 12'Oclock) while you pull from the inner edge of the same tire with the other hand (at 6 O'clock) and then switch them up and do the same thing but switch which hand is pulling and pushing. You should see no play in the wheel if your bearings are tight.
Old May 8, 2012 | 09:46 AM
  #35
g35OnTrackz's Avatar
ok wiil do..thanks
Jnm07
Aug 6, 2015 03:03 AM
bjo16
Aug 4, 2015 09:52 AM
kinetek
Aug 3, 2015 04:25 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
