Untint tails?
Dec 27, 2012 | 06:57 AM
Is there anyway to untint tail lights? I am looking to buy a coupe and it has to items tail lights and they are frowned upon in my state. Just wondering if there was a way to remove it?
Reply 0
Dec 27, 2012 | 07:20 AM
yes you can remove tinted tails. Its a big pain in the butt. You can try getting a heat gun and lightly heat the tint and if your lucky you can just pull if off.
If not, you basically need windex or any cleaner with heavy amount of ammonia and a old credit card and scrape it off.
Problem is the tint retains the heat, so if its been sitting out in the sun for a awhile, it' can make micro fractures in the plastic of the tails.
This is assuming there tinted oem tails. If there tinted aftermarket tails then no since there already smoked like that.
Reply 0
Dec 27, 2012 | 07:28 AM
Quote: yes you can remove tinted tails. Its a big pain in the butt. You can try getting a heat gun and lightly heat the tint and if your lucky you can just pull if off.
Thanks for the reply, I think they might be aftermarket tinted because I could see any tint on the outside of the lense.
Reply 0
Dec 27, 2012 | 09:54 AM
If the tint is film it will rip right off.
If its tint spray use gasoline and a towel to scrub with. It won't be easy but it comes out i did mine and they look great untinted again! Gasoline cleans the lens very well too.
Reply 0
Dec 27, 2012 | 02:13 PM
You can definitely remove the tint from your tails!
Reply 0
Dec 27, 2012 | 02:18 PM
Removing tint is so easy a cave man could do it! Squirt bottle and a few rags, find a corner and peel off. You may need Googone to remove the sticky and then a cleaner wax will finish the job. Tails should look like new....Gary
Reply 0
Dec 28, 2012 | 09:05 AM
Thanks for all the replies, I will have to look at them better when I pick up the car.
Reply 0
Dec 28, 2012 | 09:08 AM
Or there's always the option of trading someone for untinted ones
Reply 0
Dec 28, 2012 | 09:10 AM
Quote: Or there's always the option of trading someone for untinted ones
This option I will keep open also, thanks.
Reply 0
Dec 28, 2012 | 10:18 AM
I use just rubbing alcohol and a rag just hope they didn't wet sand the tails if it's VHT
Reply 0
Jan 1, 2013 | 09:27 AM
Thanks everyone for your input, I was able to go for a test drive yesterday and noticed that the tail lights have been tinted with a film. Now I know what I need to do to fix it. Thanks again.
Reply 0
Jan 12, 2013 | 09:14 AM
Untinted tails...done!
Thanks everyone for your help. As much as I liked the look, I didn't want to be harrassed by the police. Thought I would post an after pic.
Reply 0
Jan 12, 2013 | 10:10 AM
Looks good.
Reply 0
