Project started : 2004 G35 LS3 Swap - Daily Driver – Track day a few times a year
Old Dec 2, 2013 | 11:52 AM
  #121
ConradoR's Avatar
Hybrid,
In case you are debating what slim fans to get, keep in mind that there will be more clearance from the fueled racing kit than sikky kit, as the engine sits further back with the FR kit.
Old Dec 2, 2013 | 11:59 AM
  #122
stusg35's Avatar
Originally Posted by HV8RID
Thanks. Your radiator hose looks molded. Where did you get it? Did you replace your fans as well?
It's the upper radiator hose for the 2008 corvette. It fits pretty snug.
Old Dec 3, 2013 | 12:41 AM
  #123
TheDizzle's Avatar
Originally Posted by stusg35
Mishimoto dual core and dual fans.
Hey Stu, can you elaborate a little on that for a lost man? Did you get the universal dual core or one specific for the G35?
Old Dec 8, 2013 | 08:37 AM
  #124
stusg35's Avatar
Mishimoto G35 Duo core radiator with Mishimoto dual fans. Both from Chase Bays website.
Old Dec 8, 2013 | 08:48 AM
  #125
ConradoR's Avatar
btw Hybrid if you're still looking for a wiring choice, I have heard good things of Current Performance
Old Dec 8, 2013 | 11:11 AM
  #126
Mustang5L5's Avatar
That looks awesome. Would love an LS3 swapped g35. Would probably get better fuel economy too.
Old Dec 8, 2013 | 04:52 PM
  #127
TheDizzle's Avatar
Thank you Sir!
Old Dec 16, 2013 | 09:10 AM
  #128
stusg35's Avatar
Haven't heard of any updates. Hows the build coming along?
Old Dec 17, 2013 | 03:38 PM
  #129
HV8RID's Avatar
Everything stopped for 2 weeks due to a long business trip to mexico and Brazil. More updates over Christmas break I hope.
Where/how did you route your fuel lines? They come too close to the headers in stock location IMO.
What did you use for a lower radiator hose?
Old Dec 18, 2013 | 09:07 AM
  #130
stusg35's Avatar
Sounds like a nice trip.
Since my battery is in the trunk, I ran the fuel lines up the passenger wheel wells behind the liners and through the old battery compartment and drilled holes through the sides of the inner fire walls. I encased the steel braided fuel lines in rubber heater hose to ensure no contact on any metal would cause a problem while making their way through there. I also created two posts in there for the GM computers fuse box and accessories connections. It all worked out nice.
Lower radiator hose. This was a PITA. I pieced it together for now with 3 hoses. I am looking into a mandrel bent steel pipe idea. Theres another idea thats a bendable pipe, but Im really not sure if its any good. Gotta go to the muscle car shops and forums to research more. But for now, it works fine.
Old Dec 18, 2013 | 09:20 AM
  #131
HV8RID's Avatar
I was thinking of that route for the fuel lines as well but was a bit concerned of routing through the electrical area....the heater hose is a good idea though...I'm going to borrow that one....... Where / how did you go from rigid fuel line to braided? I assume the large line next to the fuel line is the EVAP. Did you connect the line to the back of the manifold up to this line? Is there somethong im missing to that bit?
Did you do a oil catch can and which one did you use?
Thanks for all your help by the way......good to get feedback from someone who has done all this recently
Old Dec 18, 2013 | 05:34 PM
  #132
stusg35's Avatar
I used a steel braided line from the tank to the Fuel rail. Then I ran the return to the regulator and then another line back to the tank from the bottom of the regulator. I dont use the infiniti lines.
I dont think its that big of a deal because the fuel lines are also encased in another sleeve of rubber tubing. Theres no way fuel could leak out.
No oil catch can. I dont like the smell they give off. Not needed.
Old Dec 19, 2013 | 09:13 AM
  #133
stusg35's Avatar
Never needed an oil catch can to start with.
Old Dec 19, 2013 | 09:58 AM
  #134
ConradoR's Avatar
Are you guys using the stock fuel lines? I plan on using a cjm stage 0 for mine due to the FAST fuel rails
Old Dec 19, 2013 | 10:01 AM
  #135
ConradoR's Avatar
^sorry just saw ur post about the braided lines from tank - regulator.
