03' g35 coupe;Engine Light just turned on, help!
Old May 24, 2015 | 02:39 PM
Barbatus's Avatar
Question 03' g35 coupe;Engine Light just turned on, help!
alright, so i bought this 03'g35 gray coupe and its a Beast. I call it "Barbatus!"
anyhow, Barbatus's engine light turned on yesterday. went to autozone, got it scanned, and codes are of the following: P1759 & P0326 (nothing else)
Troubleshooting P1759
-front break solenoid valve function probable cause
-open or short circuit condition
-poor electrical connection
-faulty front break solenoid valve
Troubleshooting P0236
-knock sensor condition explanation: the powertrain control module monitors the knock sensor signal for errors. probable cause
-knock sensor defective
-check connector and wiring to sensor
-engine mechanical condition-knock or rattle in engine
-low fuel pressure
last week and this week ran to work just on time, woke up late. warmed the car for like 3 whole minutes. both time when i reach my destination, few 8 hours later. had tranny oil on the ground. (pink and clearish color oil), i would say a total of half a mug of oil. between the first and second time barbatus leaked, the cars initial acceleration is lacking. i let go of the pedal and let rpms settle and it run again on the second attempt.. this has happend about 2-3 times... note:low accelation.
can someone walk me thru on checking each probable causes, to verify myself. i really would love to know my vehicle...
Old May 24, 2015 | 07:23 PM
upallnight's Avatar
http://nissanhelp.com/diy/obd_codes/p0326.html
If you know how to do an ohm reading see if the knock sensor is open or closed, otherwise try replacing the knock sensor.
Old May 25, 2015 | 07:53 PM
Barbatus's Avatar
just to kill time, i just went ahead and bought the knock sensor... now, finding the location of this sensor is just a pain...
any videos could help, if u or anyone else knows one..
Old May 26, 2015 | 09:23 AM
Mustang5L5's Avatar
http://www.nicoclub.com/FSM/G35/Coupe/2003/ec.pdf
Page 296. Looks like front of the top of the intake manifold...even with the oil fill port
For troubleshooting help, refer to these.
P1759
http://www.nicoclub.com/FSM/G35/Coupe/2003/at.pdf
Page 184
Old May 30, 2015 | 07:50 PM
Barbatus's Avatar
P1759
Page 184
So im trying to unscrew the lower side of manifold and cant get it unscrew without it almost strippin any advice
Old May 30, 2015 | 08:18 PM
gary c's Avatar
Welcome to Driver, congratulations you have a brain!
Glad to see a new member that is smart enough to check the codes when trouble shows up on your dash. It's important your issues get resolved without driving your G for any length of time. Take it to your mechanic or Nissan and get everything fixed especially the tranny leak!
Gary
Old May 30, 2015 | 09:49 PM
Barbatus's Avatar
Gary
Indeed gary. As u can see. Its been almost a week or so. Ive went ahead today and open the intake manifold. I was able of course to remove the upper half. To remove the lower half was a pain. There were a nut infront of the manifold and another on the back side. These 2 nuts were actually driving me nuts. I attempted to remove but almost stripped it. So i stopped. Are these the nuts i need to remove for the lower part of the manifold?
03' g35 coupe;Engine Light just turned on, help!-forumrunner_20150530_214812.jpg
03' g35 coupe;Engine Light just turned on, help!-forumrunner_20150530_214852.jpg
03' g35 coupe;Engine Light just turned on, help!-forumrunner_20150530_214905.jpg
Old May 30, 2015 | 10:08 PM
Barbatus's Avatar
btw, what kind of tranny fluid should i use, i bought http://www.autozone.com/motor-oil-an...id/830382_0_0/ i hope it works right
Old May 31, 2015 | 12:43 PM
Urbanengineer's Avatar
We here on the forum have heard horror stories of using non-OEM fluid. The Matic fluid has some unique additives others may not. I wouldn't recommend saving a few bucks on the transmission fluid change, but it is up to you.
Not sure the bolt, but http://www.nicoclub.com/FSM/G35/". Not sure if that worked...
mjfenix
Jul 24, 2015 05:16 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
attarday
Jul 15, 2015 04:03 PM
Jadenkid22
Jul 14, 2015 12:33 AM
