Carputer installed! (many many pics)
Old Feb 27, 2005 | 04:26 AM
dwoloz's Avatar
My in car computer installation has completed
The computer is responsible for navigation, MP3 music playback, video playbkac, web browsing, traffic reporting, gaming and anything else a computer is capable of
The system utilizes a VIA Epia M10000 mainboard, 256MB PC2100, 40GB 2.5" 5400RPM HD, 802.11g PCI card with external magmount 7dbi antenna, Opus DC-DC 90W PSU
Note that Im not using an inverter in this setup but rather a specialized in vehicle computer powersupply made by Opus Solutions. It regulates the DC battery voltage to a proper 12v and then also provides the startup and shutdown control for the computer (controlled upon ignition/acc wire)
Here are pictures detailing the progress and final result
To house the motherboard, I constructued a fiberglass mounting surface. This was my first time fiberglassing or doing anything similar to this so it isnt masterful but I am not a master.
Masked off area where fiberglass is to be applied
Further masking now with foil
Result before trimming edges
Motherboard mounting surface
Fabric stretched
Carpet applied
Old Feb 27, 2005 | 04:27 AM
dwoloz's Avatar
Here is the rest of the build
The motherboard, hard drive and Opus PSU with motherboard mounting surface
All the wires
I used RG59 coaxial for audio. Its cheaper than good RCA interconnects and provides decent audio quality. Here is the coax feeding into coax to RCA adapters and then into an RCA to 1/8in adapter
DigitalWheelz LCD housing (Xenarc 700TSV)
Car in a state of shambles
My dog keeping me company
Inline fused battery connection fed through the stock grommet
Battery connection fed down into the passenger side behind the kick panel
Power wires running under the carpet
Running through a convenient plastic thing (thanks Nissan!) to the rear of the back seats
dwoloz's Avatar
Through the plastic square and into the trunk
The ground location I chose
Backseat taken out; you can see the cables run on the opposite side of the car (VGA, audio, USB)
All cables run to my trunk location
Car ripped apart - very sad looking. I had to drive the car around like this (minus the headunit) for 2 days. Got quite a few looks. People probably though I stole it
Harnesses
Headunit/HVAC removed
Work begins on integrating the DigitalWheelz mount
Plastic piece cut to fit LCD controller PCB
Old Feb 27, 2005 | 04:28 AM
dwoloz's Avatar
Mounted
PAC AAI-NIS installed
Old Feb 27, 2005 | 04:30 AM
dwoloz's Avatar
Final product of fiberglass enclsore with motherboard mounted
Stock G35 dash?
I think not!
Frontend software
Music
GPS
Desktop
Goooooooooooogle
Well thats it
I had a carputer setup in my previous car (93 Accord) but this is most definitely an evolution from that. Ive learned a lot just from experience. No one taught me anything really, just experimented, made mistakes, learned and dove in.
Im very pleased with the results
If you have any questions Ill do my best to answer them
Old Feb 27, 2005 | 04:39 AM
PearlWhite03's Avatar
All I can say is WOW!!!
Old Feb 27, 2005 | 05:31 AM
accordfreak's Avatar
looks good man! how big is the monitor? do you pay monthy for the satellite internet or something?
__________________
My blue interior lights
https://g35driver.com/forums/lighting/39381-stage-4-done-blue-ac-compass-temp-display.html
'04 TB 6mt nav
Old Feb 27, 2005 | 05:47 AM
chuckd05's Avatar
siiiiccckkkkk
Old Feb 27, 2005 | 07:22 AM
SilverII's Avatar
Looks very nice....how about a write-up?
Old Feb 27, 2005 | 07:54 AM
Jack_n_coke's Avatar
I am speechless, props to you for taking a chance and doing something like this.
Old Feb 27, 2005 | 08:47 AM
KillaG's Avatar
That's creative!!!!
Old Feb 27, 2005 | 08:51 AM
Frostya's Avatar
Damn that's nice... what software are you using for the front end?
Old Feb 27, 2005 | 09:07 AM
Andy77's Avatar
What a job! Congratulations on all aspects!! it looks great in the front and in the trunk.
Old Feb 27, 2005 | 09:24 AM
madchef's Avatar
Very nice work, real clean job of running the wires!
What are you using for Nav?
What were some of the problems you ran into?
Old Feb 27, 2005 | 09:31 AM
kenchan's Avatar
That's awesome!
Your dog explained how long this mod took you to install. hahaha! j/k
