2004 G35 coupe problems
Old Jan 11, 2018 | 06:54 PM
204G35's Avatar
Hi everyone I have a 04 coupe that I’ve been having some problems with. It started with my ebreak and battery light coming on very dim, tested battery and alternator and everything tested fine. Replaced battery terminals and nothing changed. Lights still on (very dim). Then my abs light would start flickering on and off and I could hear the pump clicking. Now the abs light is always on as well as my VDC off (they don’t work now) I’ve tried looking this up but can only find posts where the ABS, VDC AND SLIP lights are on, but my slip light is not on. The vehicle now Misfires all the time, engine light is on but no codes about the misfire. What could this be? I’m totally stumped. Here are the codes I got when I scanned it
P0500, P1574, P1212 and U1001.
Old Jan 11, 2018 | 07:38 PM
telcoman's Avatar
Veteran: Army
Originally Posted by 204G35
.... tested battery and alternator and everything tested fine. .
How did you test the battery and how old is it?
Have you consulted the FSM?
http://www.nicoclub.com/service-manu.../Coupe/2004/ec
Telcoman
Old Jan 11, 2018 | 07:39 PM
204G35's Avatar
Telcoman
Tested it with a volt meter, everything checked out fine with car off and while running under load. Battery’s about a year or 2 old if that
Old Jan 11, 2018 | 07:58 PM
telcoman's Avatar
Veteran: Army
Test it again
Telcoman
Old Jan 11, 2018 | 08:03 PM
204G35's Avatar
Test it againk
Telcoman
I tested it about a week ago, but I don’t have any problems with any of my electronics, like none of my lights dim or anything like that, what is that in the picture?
Old Jan 11, 2018 | 08:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You don't test a battery with a digital multimeter, you test the electrolyte with a hydrometer as posted above and you also test with a "load bank" that most parts houses have to test batteries.
A load bank basically makes the battery power a large heating element and a fan to simulate a 100amp current draw while it simultaneously measures for voltage drop. If it drops below spec during the load test it's garbage.
Using a digital multimeter to measure voltage without any kind of load on the system doesn't tell you much really.
Old Jan 11, 2018 | 08:25 PM
cleric670's Avatar
BANNED!!!
Also since your ALTERNATOR can supply a sustained 120amps while the engine is running you have no way to measure life of the BATTERY while it's connected to the car. It needs to be disconnected while load banking.
Old Jan 12, 2018 | 07:30 AM
telcoman's Avatar
Veteran: Army
Testing the individual battery cells with a battery hydrometer can tell you if one or more cells are weak and are not accepting a full charge.
During three repeated tests of my five year old battery over the course of a month last October produced these results on one battery cell.
I had the dealer replace my battery during a routine oil change and when it was two below zero here in NJ last Saturday my vehicle started right up.
Telcoman
Matt35S
13
Feb 19, 2021 04:02 PM
Reezlah
Aug 29, 2009 02:25 AM
Reezlah
Aug 27, 2009 11:30 PM
damani
Mar 8, 2007 08:26 AM
dovla
Oct 14, 2005 11:43 AM
