Low idle after installing HFC?
Old Mar 18, 2018 | 11:42 PM
04Joe's Avatar
I installed R HFC by fast intentions on friday, and drove the car to work today. On my way home I noticed car was idling REALLY low, thought it would shut off but maintained at 200, no CEL. I'm gonna check all plugs+vacuum lines under the hood, cause maybe I just noticed it, but it may have started before. But would anything HFC related result in a low idle, the 02 sensor should throw a CEL right? Anything else it might be?
Old Mar 19, 2018 | 12:46 AM
04Joe's Avatar
I'm also thinking of disconnecting the battery and letting the car reset itself. But besides double checking all plugs/sensors under the hood and vacuum lines, what else do you guys think this could be? Thanks
Old Mar 19, 2018 | 02:17 AM
Magneu's Avatar
5 Year Member
G35C 5AT
Do the full list of resets, IIRC Motordyne has a full list somewhere on their site. Doing the battery method works as well, but it's always good to know the pedal methods.
I have HFC, catback, intake, spacer, and my idle is perfectly normal, so you definitely have something going on. If the resets don't work, definitely make sure you check lines.
Old Mar 19, 2018 | 05:43 PM
04Joe's Avatar
disconnecting the battery worked, just wierd because i thought you only have to reset after doing anything related to air or fuel delivery, not exhaust. Thanks for the input guys
Old Mar 20, 2018 | 01:58 AM
Magneu's Avatar
5 Year Member
G35C 5AT
Exhaust is kiiiiind of air delivery. An engine is just a giant air pump; altering intake or exhaust will alter the overall flow. Best to just play it safe and reset after any modifications.
Old Jan 27, 2019 | 01:46 PM
Rudy Classic's Avatar
idle
Mines does is as well as we speak I’ve done everything peddle method change maf sensor an clean TB did you just disconnect the negative side of the battery ?
Old Jan 27, 2019 | 03:03 PM
04Joe's Avatar
yes, I just disconnected the negative for a little bit, maybe 30 minutes, but I think maybe 10 minutes should be fine. when I reconnected it, it was fine again. good luck man, let me know how it goes.
Old Jan 27, 2019 | 05:26 PM
gary c's Avatar
Most modifications you do to our G35's require your disconnecting the negative side of the battery while installing...but not much more than an hour, and never overnight!
Gary
Old Jan 27, 2019 | 06:34 PM
FreshLikeAG's Avatar
Gary
why??
Old Jan 27, 2019 | 08:44 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Only seconds if you just pedal dance an ECM reset However it won't affect your idle, you need to pedal dance an idle air reset for that one.
https://nicoclub.com/archives/g35-35...procedure.html
Old Jan 28, 2019 | 02:56 PM
gary c's Avatar
Here's why FreshLikeAG!
Originally Posted by FreshLikeAG
why??
Sitting over night being unplugged your ECU can get very stupid, nothing works as intended! Last and only time I made this mistake my idle was barely 200 rpm along with everything else being screwed up. Took SLICK to my favorite GT-R mechanic (Nissan) and he reset everything within minutes with his hand held...no charge!
Gary
Old Jan 28, 2019 | 06:49 PM
Idle
Yea I’m still low tried everything idk what else it Could be my 1st an 2nd gear is rough low idle an my accessory lights has a slight flash to it battery is good but Alternator is at 15volts
Old Jan 28, 2019 | 09:24 PM
cleric670's Avatar
BANNED!!!
Are you making sure to do the idle air recalibration when the engine is FULLY up to temp (including transmission) and with EVERY power consumer turned off? This includes radio, AC controller (completely off, not just the fan turned off), headlights, etc.
If the lights don't flash properly during the recalibration then you didn't do it right.
Old Jan 29, 2019 | 03:53 AM
Yes I have might have to check the TB
saywat?
Sep 29, 2011 04:27 PM
ramo
V36 Engine, Exhaust, Drivetrain & FI
19
Nov 11, 2008 09:11 PM
.:Brown Man:. J
Jan 8, 2007 05:49 PM
ireloaded9
Apr 12, 2005 09:11 PM
gdupg35
Intake & Exhaust
11
Feb 16, 2004 06:56 PM
