What is this sound coming from?
Old Mar 9, 2019 | 07:01 AM
G35BYKD's Avatar
Infiniti G35 Coupe
Does anyone know why my G is making this noise? I doubt its rod knock or anything like that. I've already done an engine swap because my original engine had the clicking sound. This isn't the same noise. Please respond asap. Copy/Paste the link below for a video of it.
IG: G35BYKD
https://drive.google.com/file/d/1yo_jbYufKCNitUzTZ0CLavt-KBMbGkLb/view?usp=drivesdk
Old Mar 9, 2019 | 07:04 AM
Scorpi0's Avatar
Sounds like one of your plastics is scraping on the ground.
Old Mar 9, 2019 | 07:36 AM
G35BYKD's Avatar
Infiniti G35 Coupe
There's nothing touching the ground. Just checked.
Old Mar 9, 2019 | 11:57 AM
partyman66's Avatar
Check to make sure there is nothing like a plastic bag or piece of paper wrapped around or stuck to the undercarriage rubbing against the driveshaft. Look up into the well too as it could be out of sight from a straight across look from the side.
Old Mar 9, 2019 | 12:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I remember someone saying it was the silicone chunks in the coolant system from something failing. I thought it was for the V36 chassis only though but maybe not.
Old Mar 9, 2019 | 12:22 PM
cleric670's Avatar
BANNED!!!
If the sound is coming from the engine bay then stop driving it immediately, you may have broken a timing chain guide. If it's coming from directly under the seats then it may be rattling heat shields on the catalytic converters.
Old Mar 9, 2019 | 01:50 PM
G35BYKD's Avatar
Infiniti G35 Coupe
Maybe it is the shields. I didn't even think about that. I'll check on that when I get a chance. It's definitely not from the engine. I bought a fresh engine and already had it checked by Nissan. The sound isnt coming from the front at all.
Old Mar 9, 2019 | 01:54 PM
cleric670's Avatar
BANNED!!!
Also, don't discount debris under the vehicle. I had a rattle that drove me insane for about a month. I went under the vehicle with a big security inspection mirror multiple times, even had the car up on a lift trying to find the problem. When I was traveling 20-50 mph it sounded like a plastic bag was stuck under the car.
I eventually found the problem, it was NOT what I thought it would be... lemme dig through some old photos and I'll find the picture of the culprit.
Old Mar 9, 2019 | 01:58 PM
cleric670's Avatar
BANNED!!!
THIS LITTLE TWIG! It was wedged into a drain hole in the chassis and was just barely touching the ground. I had seen it multiple times when inspecting under the vehicle but thought there was no way in hell it could make so much noise that sounded exactly like a fluttering plastic bag under the car. You could hear me coming from a block away.
Old Mar 9, 2019 | 02:11 PM
G35BYKD's Avatar
Infiniti G35 Coupe
😂😂 Hopefully my noise is the heat shield or something as minor as a stick. I'll follow up when I can.
Old Mar 9, 2019 | 02:41 PM
partyman66's Avatar
Been doing some G35 offroading there Cleric?
Old Mar 9, 2019 | 08:05 PM
Magneu's Avatar
5 Year Member
G35C 5AT
I had the same thing happen a few weeks ago! Almost the same size, wedged itself under the body where the side skirts meet the chassis. Thought I was dragging something metallic, was just wood on asphalt. Strange how it was so loud.
Old Mar 9, 2019 | 10:52 PM
Scorpi0's Avatar
Mother nature doesnt like G35's apparently
Old Mar 11, 2019 | 10:56 AM
partyman66's Avatar
Wait until your sunroof drains start plugging up and flowing water into your interior during rainstorms. Huge PITA to fix.
Old Mar 12, 2019 | 12:11 AM
Scorpi0's Avatar
I'll just drill a few holes through my capet and let it drain out lol
Tacho Aguilera
Mar 21, 2016 08:17 PM
Pratik
Mar 20, 2006 02:07 PM
Gthree5 6MT
Hawaii
Aug 31, 2005 03:02 PM
SFLG35
14
Oct 8, 2004 01:15 PM
AntRock
Sep 3, 2003 11:02 PM
