Gas gauge is not reading correctly
Old Oct 15, 2019 | 03:42 AM
D.j. Point's Avatar
Infiniti G35
Gas gauge is not reading correctly. I already tried cleaning the floats under the backseats I even replace both of them and still the gas gauge doesn’t read right What are other option I can try?
Thank you in advance.
Old Oct 15, 2019 | 08:11 AM
telcoman's Avatar
Veteran: Army
Fuel level sensor
https://www.nicoclub.com/FSM/G35/Sed...5_Sedan/fl.pdf
See page FL-13
CAUTION:Sub fuel level sensor unit cannot be disassembled and should be replaced as a unit.Remove fuel level sensor unit as follows:1. Disconnect harness connector (A).• Hold connector by fingers and pull it out, because there is nostopper release tab.
Old Oct 15, 2019 | 09:26 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Into on how to test for proper signal is in section DI - Driver Information.
Old Oct 15, 2019 | 04:44 PM
jbarnett250's Avatar
Search for fuel gauge problem - detailed thread. There are descriptions of how several people resolved their different gauge problems including problems with the cluster in this thread.
Old Oct 17, 2019 | 09:54 AM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Question for someone who's had their g since new. Have the fuel gauges on these cars ever been right and if so how long did they last? Oh, and is re-soldering the pins on the cluster the last resort or is it pretty common? Thanks!
Old Oct 17, 2019 | 10:43 AM
telcoman's Avatar
Veteran: Army
On my first 06 G35 speed manual over six years I traded it in with 171796 miles. Never has a fuel gauge problem
On my second Infiniti a 2012 G37S over another six years I traded that one in just short of 95k miles and never had a fuel gauge problem
On my third Infiniti a 2016 Q70 with eighteen thousand miles I never experienced a fuel gauge problem
I've seen many posts over the years with many having this issue with different year and model Infiniti's
I'm wondering if the root cause is that many of those possibly putting additives into their fuel tanks that may be the cause of this problem?
FWIW I only use regular 87 octane in all of my Infiniti's and have never used any additives or used any non Infiniti parts
Old Oct 17, 2019 | 09:06 PM
It's not that soldering the resistor is some kind of last resort or something. It's just easier to check the senders first using the instructions above. If you check all the easy stuff first and everything is fine, then eventually you need to check the cluster. If you can solder, it's pretty easy to repair yourself using the diy on this site. If you can't solder, it seems there are a few places online that will repair the cluster for relatively short money. I don't know what percentage of these failures are the senders and what percentage are in the cluster. I only know mine was in the cluster. I read lots of stories here with people cleaning and replacing sensors and not fixing the problem so my gut tells me it's more often in the cluster.
I wasn't the original owner but the gauge in my 06x was fine until 2017 and about 230k miles. And then it did the thing where it would indicate normally for the full half of the tank and then get stuck and indicate half tank no matter how little was in the tank. Seems like this is one of several common bad gas gauge symptoms.
Old Oct 18, 2019 | 10:16 AM
FreshLikeAG's Avatar
It's definitely accurate but when you think you're on E, you really should have 3,4 gallons left. I've never been able to pump more than 16 gallons in the tank
Old Oct 18, 2019 | 01:03 PM
cleric670's Avatar
BANNED!!!
I put in 19 gallons once, I was on empty empty empty.
Post 72 on this thread details the resistors that need to be re-soldered to fix the gas gauge IF that's your issue, definitely read resistance on both harnesses on the fuel tank though since that's a super easy test. 30 seconds to remove the back seat, unplug both harnesses, measure resistance, compare to what the fuel level on the dash says, plug in harnesses, snap seat back on.
https://g35driver.com/forums/g35-sed...ml#post7130715
Bassman
Dec 8, 2011 10:32 AM
skazz781
Aug 3, 2011 09:32 AM
Bane
Oct 25, 2007 05:04 PM
MightyG35
Jan 19, 2005 03:48 PM
