Does purchasing positive/negative terminal ends matter?
Old Feb 12, 2024 | 05:38 PM
ehlten2's Avatar
Infiniti G35 2D
I noticed my terminals were corroding and causing the car to have difficulty starting on cold starts. I was looking to replace both terminals (positive and negative) in hopes of fixing the issue. I looked on Rockauto, however, they only provide positive terminals with no sign of negative terminals. I looked on Infiniti Parts and they don't specify positive/negative for the terminala. I'm assuming the terminals just conduct and bridge the electricity from the electrical system to the battery. That leads me to the question, does it matter if the terminals is listed as positive/negative? Can I purchase the positive terminal from RockAuto and use it for the negative terminal on my battery? If it does matter, is there a link to a negative terminal? Thanks for the help!
Old Feb 14, 2024 | 05:18 AM
Scorpi0's Avatar
Usually people just clean their terminals with a wire brush and some type of cleaner. As long as its not worn out to the point of being loose, then u should be able to clean it and reuse it. U can also slather some dielectric grease or vaseline over the whole thing so it prevents it from corroding again.
But no, theres no difference between positive and negative terminals. All they do is just conduct electricity.
Old Feb 15, 2024 | 02:59 AM
Polishthrust's Avatar
I replaced the positive terminal just to get things looking clean, its only a few bucks.
Old Feb 17, 2024 | 04:39 AM
Atelis's Avatar
1st Gen G35 coupe base. 165k. No mechanical or ECU issues. But I will see if any come up after maint
Lead battery terminals are universal and the same terminal will work for either the positive or negative battery post. Just make sure they fit properly or you'll result in a dead battery. I would get the voltage tested as well and anything under 14volts, get a new one with higher CCA if you're in a colder environment- 30F or colder.
Old Feb 17, 2024 | 07:00 AM
Scorpi0's Avatar
I think he meant to say 12 volts.
BarrackObama230
V36 Audio, Video & Electronics
Jul 24, 2022 11:20 AM
SpX
Canada
14
Aug 20, 2009 11:12 PM
nyckid
Aug 8, 2006 06:38 PM
malx
May 24, 2006 05:35 PM
osamabinwayne
Nov 1, 2005 11:32 AM
