What is Causing this sound?
Old Jul 19, 2025 | 09:46 PM
JstcG35's Avatar
Infiniti G35 Coupe w/ Brembo Sport package
Clunking in Steering wheel?
Hi, I have a 2004 6mt coupe that I have so far done basically a bunch of done to the suspension short of coilovers (which are on the way) but also including rack and pinion, outer tie rod replacement, steering u joint replacement, and clockspring replacement that i have done. Recently I've started hearing this clunking in the steering wheel that I think is coming from the steering shaft itself but I wanted to get some more opinions before I jumped to conclusions, below is the video of the sound.
File Type: mov
Last edited by JstcG35; Jul 19, 2025 at 11:49 PM. Reason: Wanted to be a little more clear in the title
Old Jul 30, 2025 | 02:05 AM
JstcG35's Avatar
Bump, Anyone?
Old Jul 30, 2025 | 04:01 PM
Mr.GEE's Avatar
20 Year Member
Remove the shroud around the steering column and see if there is something loose or scraping. It could be anything from the clock spring to steering column coupling. Go to the link below and find the correct section for steering. It will give you exploded views of the parts and instructions on how to remove them. If you attempt anything around the steering wheel itself, disconnect the battery and press on the brake pedal to neutralize any residual voltage present. You don't want the air bag deploying and sending you to the hospital.
https://www.nicoclub.com/infiniti-service-manuals
Old Aug 5, 2025 | 05:36 PM
JstcG35's Avatar
Update: ended up finding out it was the angle of adjustment I had for the steering wheel and guage cluster that was putting strain on the steering shaft. Messed with it for a bit and got it to go away.
charmer37
Aug 28, 2023 02:49 PM
P.F.
Jul 9, 2013 10:59 PM
malicemethods
Jan 21, 2013 02:47 PM
kendroz
May 5, 2012 07:29 AM
gdupg35
Nov 23, 2003 02:28 AM
