Tiptronic How Often?
Old Apr 25, 2005 | 02:28 PM
Pwoz's Avatar
Originally Posted by HomieG35
I use it when I cruise on the weekends [because of all the stops and starts and how it will stay in 3rd gear till 10mph - less shifting] or when I'm in parking lots so it wont ever shift out of 1st as I never go any faster then 15mph anyway. I love the thing and I have gotten pretty good at it where the shifts can be smoother than when I'm in D if I want them to be.
How does a shift get any smoother or rougher on an automatic transmission? The manual mode doesn't change how fast it actually shifts from one gear to the next. There isn't any clutch that you are controlling to make it smoother or not.
Old Apr 25, 2005 | 03:07 PM
EZZ's Avatar
EZZ
There is quite a bit of difference in how the manual mode feels than automatic mode in terms of shift quality. The auto mode is seamless and is completely smooth while in manual mode, if you shift too early, there is definitely a harsher shift. If you mimic how the computer shifts in terms of rpms, you get a smooth shift (just like auto mode). I bet the computer doesn't adapt fast enough in manual mode thereby creating the difference between the auto mode and manual mode.
Old Apr 25, 2005 | 03:19 PM
TINMAN's Avatar
every now and then i used it.only to see that needle goes up to 7300-7400rpm
Old Apr 25, 2005 | 03:38 PM
seairland's Avatar
Originally Posted by kenempireex
except it's easier.
I dont think you get the same feel for the car.
Old Apr 25, 2005 | 03:45 PM
Kyosho's Avatar
thats right. you dont. i use it about.. 100% of the time now
Old Apr 25, 2005 | 04:41 PM
truplay8's Avatar
THE BATMOBILE
every time i use it i feel like im doing it wrong........idk what it is but its just not smooth and i feel like im hurting the car
Old Apr 25, 2005 | 04:57 PM
Andy77's Avatar
I use MM about 15-20% now. My usual short drive to work is suburban streets with no speed or high RPM appropriate and stop-and-go (kids going to school-I pass three of them on the way). On the on-off ramps, passing and more fun roads I enjoy using it.
Old Apr 25, 2005 | 06:03 PM
g35noob's Avatar
i have never used auto except for passing by it into manual mode.
Old Apr 25, 2005 | 06:17 PM
heeb's Avatar
I used to use it in a straight drag, but found that straight up "DRIVE" is faster. You'll get much smoother and faster shifts, but I still use MM mode from time to time.
Old Apr 26, 2005 | 01:19 PM
gripitandripit's Avatar
what is the best way to drive in MANUAL MODE to prevent a rough ride?
choosier
Nov 25, 2006 12:14 PM
Wizzathe1337
Feb 20, 2005 07:33 PM
G35Rush
Jun 29, 2004 03:19 PM
dennis_said
Jun 22, 2004 12:45 PM
RJP6
May 17, 2004 05:05 PM
