Reseting the ECU? After the break-in period....
Old Jun 5, 2003 | 11:19 AM
jcboiz's Avatar
Hello everyone, I was reading one of the posts https://g35driver.com/forums/showfla...sed&sb=5&part= basically the person said that we had to roll down the windows or else "your @#$#ed" can someone tell me why that would be if you don't roll down the windows and disconnecting the battery? Thank you!!!
Old Jun 5, 2003 | 11:46 AM
sofl_g's Avatar
Re: Reseting the ECU? After the break-in period....
The G coupe lowers the windows when opening the door and raises them AFTER the door is closed. If the battery is disconnected and the door is opened and closed the window will strike the lower edge of the roof as the window will be in the full up position. Say hello to chipped paint and who knows what else.
Currently driving 93 RX-7 TT. Very seriously considering selling the RX for a G-35 coupe.
Old Jun 5, 2003 | 12:14 PM
COUPEDIT03's Avatar
I thought that feature was to prevent air pressure in the car caused by doors being closed.
"Dont start none, won't be none"
Old Jun 5, 2003 | 03:52 PM
tec243's Avatar
That's correct. Don't know if you remember the older Camaro's wobbly windows that had to flex everytime the door was shut. Seems this short down/up when the doors are open/shut will preserve the window integrity. I noticed the Boxster has this feature too. ...dean
Seattle 'Eastside' area
'R' Order - IP/Graphite 6MT Coupe; Prem., Nav. & XM [img]/w3timages/icons/smile.gif[/img]
Old Jun 6, 2003 | 01:06 AM
jcboiz's Avatar
I understand that now....thank you for your info!!!! Have you reset your ECU? Does it make that big of a difference?
Old Jun 6, 2003 | 04:18 AM
wickedG35's Avatar
I reset my ECU with windows fully rolled up... nothing happened, everythings fine
-Blk/Blk G35c
Old Jun 6, 2003 | 03:45 PM
gsg's Avatar
gsg
Has anyone determined if it can be reset by pulling a fuse rather than disconecting the battary?? If you can do it with a fuse, which one and where is it located?
Using a fuse would be easier and also elimimate the window question and resetting the radio presets or other items affected by loss of power.
Old Jun 6, 2003 | 03:55 PM
99atlantic's Avatar
i have (although i'm too lazy to click that link but i think i made the post, hehe) and I liked it. Breathed new life into my car
and for resetting the radio, it's easy
1) am
2) press scan
3) hold '1'
4) wait for beep
5) press scan
6) hold '2'
etc...
repeat for 3-6 and then for fm, fm2, takes like 1minute.
www.ironpumping.com
^^Bodybuilding Made Simple
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
