Wheel squeak when first pulling out
Old May 17, 2006 | 01:59 AM
SithSolo1's Avatar
For the past 2 months(happens more now than it did at the beginning) my left rear wheel squeaks when I first pull out of the garage for the day(regardless of time of day or weather) and continues to squeak for 100 or so feet and then stops. Doesn't do it again for the rest of the day. Any idea what could be causing this? Car is a '05 coupe AT w/ sports pack and is 10months old with 6300 miles on it.
Old May 17, 2006 | 02:05 AM
f150rx7's Avatar
does it go away when you apply the brakes?
Old May 17, 2006 | 02:12 AM
SithSolo1's Avatar
Not all the time. I've tried "stomping" on the brake pedal to see if I can get it to stop. It's worked once or twice but most of the time it keeps squeaking for a little bit further down the street. It's weird.
Old May 17, 2006 | 02:26 AM
uberchicken's Avatar
i don't understand a lot of the questions from people with cars under warranty.
If it's under warranty, bring it in, get the loaner, and get it fixed. That way the record of the problem is recorded.
Old May 17, 2006 | 02:31 AM
speedracerg35's Avatar
not trying to minimize your problem, but most cars left out in the elements will develop a layer of oxidation on the rotors. if left for three or four days undriven, you can see the rust that forms. my car is garaged, and if i don't drive it for a while, the car will squeal a little until i get the oxidation off by the application of the brake pedal several times.
Old May 17, 2006 | 02:42 AM
SithSolo1's Avatar
I realize that the dealership could tell me what the exact problem is but given traffic the nearest dealership is 3hrs round trip. I'd be slightly ticked if I made the trip and then was told flatly that there is nothing wrong and that's probably oxidation. Hence asking here and hoping for people like speedracer to reply.
The oxidation makes sense to me. I drive my car every day but the "garage" is basically an open parking area under my condo complex so it's totally open to the elements. Just weird that it only affects the left rear.
Old May 17, 2006 | 11:43 AM
brisk's Avatar
thats exactly the problem that i have except it seems like mine is coming from the rear right...couldn't reproduce it at the dealership, but they think its the brakes and will look into it...
Old May 17, 2006 | 12:01 PM
radjack79's Avatar
That is excatly what I think it is as well...it just takes a few rotations of the tires to clean up the rotors and the sound should dissapear. Happens to me as well.
Old May 17, 2006 | 01:15 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I have almost the same car, and i hear a squeeky noise from the driversside, sometimes when i make left turns...
Old May 17, 2006 | 01:19 PM
nnkfws333's Avatar
it could be possibly from brake dust....happens a lot
Old May 17, 2006 | 09:45 PM
I do get a bit of rust on my motorcycle rotors if I don't use them as they were meant to be used, HARD! They are brembo and have a high iron content.
Old May 17, 2006 | 10:23 PM
boxa87's Avatar
i know that the car does an auto brake check when you hit 10 MPH maybe something went ape **** in the ECU and its not unlocking after the check starts i would take it to the dealer.....
snic09
Nov 8, 2017 01:46 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
ddietz97
Jul 26, 2015 06:16 PM
