Calling all "X's" with a lowered suspension!
Old May 30, 2011 | 08:25 PM
  #1981
h23sdominate's Avatar
within the next month im taking the h techs off and getting s techs. I want more of a drop.
Old May 30, 2011 | 10:34 PM
  #1982
04G35NYC's Avatar
^ S techs are horrible springs, the drop is mad low but you will hate the ride quality, i would go with Coupe H&R's you will be much happier with them just saying.
Old May 31, 2011 | 01:07 AM
  #1983
are we talking stiff as far as ride quality goes?
Old May 31, 2011 | 11:15 AM
  #1984
04G35NYC's Avatar
Yes the ride quality is terrible on the car.
Old May 31, 2011 | 11:58 AM
  #1985
Wilg35j's Avatar
Doe sd genius have sedan h&rs i was planning on getting a set?
Old May 31, 2011 | 08:28 PM
  #1986
Old May 31, 2011 | 10:57 PM
  #1987
04G35NYC's Avatar
I have H&R's they are the best springs i have had, good drop and very good ride quality. I went thru 4 different springs till i found H&R's being the best and i had BC coils as well.
Old May 31, 2011 | 10:58 PM
  #1988
did you go with the sedans or the coupes?
Old Jun 1, 2011 | 09:58 AM
  #1989
acr's Avatar
acr
Originally Posted by FlyingLumpia
Yes the rear ride height does not go as high as we want it to. You can contact BC and they can send you out a spacer for 40 bucks I think. It will go on the spring and raise it about 1/2-1 inch I believe.
How much of a drop does the "highest" setting on the BC coils yield? I'm getting ready to buy BC coils, but don't want more than a 1.5" drop so that I can hopefully avoid the problems/worries that come with a slammed car.
Old Jun 1, 2011 | 10:30 AM
  #1990
Wilg35j's Avatar
Sedans or coupes???
Old Jun 1, 2011 | 10:41 AM
  #1991
04G35NYC's Avatar
Originally Posted by Wilg35j
Sedans or coupes???
I have Sedan H&R's on my RWd. With AWD the drop is obviously lower but still looks hot and very comfortable ride.
Old Jun 4, 2011 | 05:05 PM
  #1992
Gdirtyfiver's Avatar
Hey this is for all you fellow bc coilover owners out there, have or did any of you guys max out your CO's height during the winter and how close was it to stock? I've read here that the backs don't go as high as the fronts so I'd have to order the additional ring to go on the back spring for an additional $40? I bought mine back in November but I read somewhere they revise it? Not sure winter is a ways away haha but just wanted to know so I can get them put in now so when winter comes I can just crank it up!
FYI - after 5k miles so far so good but still wanting to tinker around with the ride comfort. I know how to adjust preload in the fronts but anyone know how to do the preloads in the back or have a write up of that? I'm sure there's a way to "perfectly" match shock height to spring height" but just wanted to know you're guys knowledge on that. So far so good thought for those considering bc's IMO
Old Jun 6, 2011 | 05:45 PM
  #1993
apintojr's Avatar
i too have been looking for a write up for the rear but i havent found anything yet. but alot of people suggest adjusting the spring first then the shock to match.
@flyinglumpia - how much preload did you set your fronts? i beleive factory was 5mm, i have mine at 10mm.
Old Jun 6, 2011 | 05:50 PM
  #1994
OKStateG35's Avatar
I have a popping noise coming from my front suspension and from reading it sounds like it might be the swaybar endlinks. Anybody else have theirs go out even with a mild drop and stock sways? I know it's a common problem on these cars, but it usually seems to happen to those guys with aftermarket swaybars. I guess changing the springs out probably speeds up the wear on them as well.
Old Jun 6, 2011 | 05:51 PM
  #1995
apintojr's Avatar
+++++1 on that all day. before the BC. i had H&R and i beleive were the best springs for us AWD guys. great drop,not slammed and great quality spring.
i also had tein h-type. did not like them at all.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
