Calling all "X's" with a lowered suspension!
Old Apr 16, 2012 | 03:17 PM
  #2311
MJION's Avatar
Originally Posted by TurTLe*
LOOKING GOOD MAN!!!!! After seeing now nice the front was as you drove off, i was very pumped to do mines.
I'm pissed due to work schedule I wont even be able to consider installing my coilovers to mid may.
Yeah, thanks again.. Now hurry up and drop yours, no excuses!! haha.
Old Apr 18, 2012 | 11:16 AM
  #2312
ccc123pm's Avatar
X
Teflon, what is so bad about the ride quality on the prokit. Alot of people have sworn that they are great springs for a modest drop.
Old Apr 18, 2012 | 11:38 AM
  #2313
2006g35xsilver's Avatar
Originally Posted by SqueakyClean35x
Will bc coilovers for 2007 g35x fit my 2005 g35x???
I think they will but I can't say for sure. The 2007x looks like it has the same suspension setup as the 05x. Try emailing BC Racing. They will answer although sometimes not the question you asked . . .
Old Apr 18, 2012 | 02:15 PM
  #2314
teflon_don's Avatar
Bouncy... most likely b/c these prokits were designed for a normal G. I have an 05X. I even replaced the rear shocks when I had them installed.
Old Apr 18, 2012 | 03:24 PM
  #2315
kidgotheat's Avatar
just recently installed my bc coils on my 04g35x about a week ago no...no camber kits yet but still dont know if i need one for the front also ...here is how it sits before and after
Attached Thumbnails Calling all "X's" with a lowered suspension!-img01367-20120121-1649.jpg   Calling all "X's" with a lowered suspension!-img01357-20120108-1204.jpg   Calling all "X's" with a lowered suspension!-img-20120417-04829.jpg   Calling all "X's" with a lowered suspension!-img-20120417-04830.jpg   Calling all "X's" with a lowered suspension!-img-20120417-04831.jpg
Old Apr 18, 2012 | 11:56 PM
  #2316
Cpoups's Avatar
Here are a few pictures of my 05 G35x sedan with 19 inch VMR 710's dropped on coupe springs on the front and stock springs rear.
Attached Thumbnails Calling all "X's" with a lowered suspension!-vmr-sedan-001.jpg   Calling all "X's" with a lowered suspension!-vmr-sedan-002.jpg
Old Apr 22, 2012 | 03:53 PM
  #2317
nlallen141's Avatar
Before:
Unrevised Z Springs.
After:
Slammed on BC Coils
Conclusion = Coils > all
Old Apr 22, 2012 | 04:27 PM
  #2318
MPG35fiend's Avatar
looks GREAT!^^... had my car slammed like that but roads here are super duper sucky... had to raise it cuz i kept busting my cv boots...
Old Apr 22, 2012 | 04:34 PM
  #2319
MPG35fiend's Avatar
I have an 04 g35x running 18x8.5+35, 245/40/18 all around, lowered on bc coils. My wheels poked out about 5-7mm before i put my bc coils on. After i lowered it (not sure how much bc i left the spring rate and ride height the same fresh out of the box) the wheels sat nearly flush. i have the Eibach Pro SPC rear camber kit with toe bolt adjustment. Adjusted rides height and spring rates after the coils settle.... Damper setting is at 8 clicks away from hard in the rear and 4 clicks away from hard in the front. A year later i Finally found a front camber kit made for the AWD manufactured by SPC model number 72125. Just put them on and set them at -1.2 camber in the front and the rear is set at -2.0 maxed out. before the Front Camber Kit my camber was -2.2 on the left and -2.9 on the right!... The front camber kit made a day and night difference!!! Im very pleased with my set up and stance... I will be going with a more aggressive set up soon but i use my car daily to and from work and every where else, so i kept it pretty safe...... heres before and after my front camber kit..... I HIGHLY RECOMEND GETTING both front and rear camber kit.
Attached Thumbnails Calling all "X's" with a lowered suspension!-img_3875.jpg   Calling all "X's" with a lowered suspension!-img_3874.jpg   Calling all "X's" with a lowered suspension!-img_3877.jpg   Calling all "X's" with a lowered suspension!-img_3876.jpg   Calling all "X's" with a lowered suspension!-img_3873.jpg
Old Apr 22, 2012 | 04:46 PM
  #2320
Reedtc's Avatar
Originally Posted by nlallen141
Before:
After:
Slammed on BC Coils
If you mind me asking? What % is your tint?
Old Apr 22, 2012 | 10:42 PM
  #2321
kidgotheat's Avatar
Looks nice man ..man how much of a difference blacking out window trim nd matching door handles makes
Old Apr 23, 2012 | 10:50 AM
  #2322
Aberto22's Avatar
dont know really anything about them because they did it before i bought it and its really not even that much lower. but i have a squeaking issue when i go over bumps. other than that no problems
Old Apr 23, 2012 | 07:02 PM
  #2323
The Fixer's Avatar
Looks really good, you beat me to my idea. I was thinking that would be the perfect way to even the fender gaps by just dropping the front. Now I have to find myself a set of coupe fronts! How many miles do you have on your OEM struts?
Old Apr 23, 2012 | 10:15 PM
  #2324
Gtz1stballer92's Avatar
bc coils
Old Apr 23, 2012 | 11:52 PM
  #2325
MPG35fiend's Avatar
Originally Posted by Gtz1stballer92
bc coils
dude... that looks so DOPE!!... are you running any spacers?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
