Calling all "X's" with a lowered suspension!
Old Apr 8, 2014 | 09:48 PM
  #2641
halloffamerjc's Avatar
Originally Posted by FlyingLumpia
I already tried that and didn't fit because on the inside. Its like a triangle shape in it.
I want to try boots from different cars just don't know where to start or what size would be ideal.
Old Apr 12, 2014 | 11:33 PM
  #2642
The Fixer's Avatar
I went the easy way. I built a setup with coupe front springs and new KYB struts up front, and left the stock X springs in the rear with new KYB shocks. The 1" drop up front evened out the gap with the rear wheels and looks good. We had a helluva winter this year, so I'm glad I didn't go lower. Still managed to crack my front bumper on a chunk of ice!
Old Apr 14, 2014 | 07:44 AM
  #2643
MPG35fiend's Avatar
Old Apr 14, 2014 | 07:50 AM
  #2644
MPG35fiend's Avatar
2k4g35x
Originally Posted by mpg35fiend
Old Apr 14, 2014 | 09:35 AM
  #2645
epborden's Avatar
Originally Posted by MPG35fiend
Where do you get the custom reservoirs, those look really nice! Car looks really nice, I can't imagine how much you scrape lol!
Old Apr 15, 2014 | 02:24 AM
  #2646
MPG35fiend's Avatar
thank you sir. i got them from SxExCx. they aren't cheap
and yes i scrape much more on air ride than i did on static bc i right a lot lower lol i am actually the first bagged 1st Gen G35X in the WORLD!!
Old Apr 17, 2014 | 10:59 PM
  #2647
epborden's Avatar
I have a shop investigating the true cause of the front right inner boot tear. They are going to put my car up on a dyno rack and do some angle and turn tests to see what is happening. My mechanic said it could be that due to the angle from lowering it is actually rubbing on something and causing the tear. I talked about the lowering and odd angle of the axle and it stressing the boot in various scenarios but he said it may not be that. I will report back what my solution ends up being so that all you guys with an X will know what to do.
Old Apr 18, 2014 | 06:46 PM
  #2648
Your the man bro!
Old Apr 18, 2014 | 09:43 PM
  #2649
MPG35fiend's Avatar
Yes!!! Thank you!!!! But honestly I believe the cause of the tear is bc the boot is way too short for the axels when it's angled when lowered.
Old Apr 20, 2014 | 08:42 PM
  #2650
MPG35fiend's Avatar
First Ever Bagged 1st Gen G35X 2k4g35x
Old Apr 28, 2014 | 11:32 AM
  #2651
epborden's Avatar
Got some news back from my shop. They put the car on the dyno to check the front right inner (passenger) boot, and they did NOT see that it rubs/hits anything at differing angles. They told me what I sort of already knew, which was that boot is very small and NOT designed to handle the new stress an angles from lowering the car. My mechanic said he is going to try to use the front left inner boot (driver); see if it fits, and do some stress testing on it. He seems to think it may work out, and although I've never seen it on this forum he could be right. I will update if that plan does not work out and we go another direction. I should have a definite answer on this particular X ailment in the next week or so.
Old Apr 30, 2014 | 01:09 AM
  #2652
FlyingLumpia's Avatar
Tell him to try a boot from the rear also. It might be longer and I have not heard any ripping.
Old May 25, 2014 | 11:40 AM
  #2653
zmuehl22's Avatar
will someone please clarify for me: i believe i read that rwd sedan lowering springs work just fine on the awd sedan? just wanted to double check before i look at getting the eibach pro-kit since i can not find one for AWD 06 g35x
Old May 31, 2014 | 12:57 PM
  #2654
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Think of it his way, If the 350z is RWD and members are putting Z springs on the X, don't you think that aftermarket springs for the Z would also work on the X?
Old May 31, 2014 | 11:40 PM
  #2655
zmuehl22's Avatar
that makes sooooo much sense.......made me feel like an idiot lol, but thanks
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
