Grinding noise when I brake?
Old Aug 15, 2006 | 08:17 PM
getsome's Avatar
Everytime I brake gentely with my car I hear a grinding noise from the front of the car. I took it in to the dealership, and they said we didn't hear anything. So im taking it back this friday for a couple of things. I have new brake pads and rotors what else can it be? I need some sujestions please asap, thanks.
Old Aug 15, 2006 | 09:04 PM
AlcatrazT2's Avatar
ABS related issue? Just a guess.
Old Aug 15, 2006 | 10:34 PM
andy2812's Avatar
You should monitor your rotors to see if they start scoring. You should be able to look thru your wheels to see them. You can also touch the rotor with your hands to make sure they are smooth. Just make sure the car is cold as you don't want to burn your hands when touching the rotors.
Old Aug 15, 2006 | 10:44 PM
G tHiRtY fIvE's Avatar
most likely the brake pads but i would have to hear the noise . When brake pads wear down there are little clips behind them make a scratching/grinding sound when u brake to let u know u need new pads.
Old Aug 15, 2006 | 10:46 PM
Texasscout's Avatar
Just a thought, I had a rock in mine once. It worked it's way out.
Old Aug 16, 2006 | 02:17 PM
ttrank's Avatar
Grocery getter
Your pads could be about gone.
A rotor could be wearing out.
Your pads may be dirty.
Old Aug 16, 2006 | 02:18 PM
sjc1789's Avatar
Florida G35 Club
he said he had new pads and rotors... chk for the rock.. w/e it is find it fast cause u don't want to tear up ur rotors
Old Aug 18, 2006 | 10:15 PM
andy2812's Avatar
It could still be the pads. I was getting the same grinding and my rotors were scored. The pads were still good so they just cut my rotors the first time. Within 1000 miles it was happening again and the rotors were scored again. They then replaced the front pads and rotors and after another 1000 miles it happened again. It seems the since the pads are semi metallic, they sometimes will cut into the rotors which of course creates a safety issue since the rotors aren't completely smooth although the dealer tells you that its normal and fine to drive with. Just another reason why I'll never get another Infiniti.
Old Aug 19, 2006 | 01:04 AM
AgentAero04's Avatar
It could be as simple as climate.What has your weather been like? Lots of rain?Hot and humid? It could simply be oxide build up. That well defenitely wear off....quickly.Does noise this happen every time you apply the breaks?? If it does,well,you need new callipers.You already have new rotors and pads..process of elimination.
Old Aug 19, 2006 | 06:57 AM
g35rcr's Avatar
have you checked to make sure your wheels are tightened down
Old Aug 19, 2006 | 07:56 AM
Dudefish's Avatar
I'll often hear a scraping sound from the brakes (not unique to the G, BTW) the first time I use them in the morning after it rains, as the pads scrape the light corrosion off the surface of the rotor. Second time I press the brakes, no noise. Is that possibly what you're hearing?
Old Aug 19, 2006 | 03:54 PM
soaped's Avatar
If you do touch your rotors, do not use your base hands
magnetism80
Feb 1, 2019 10:00 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
3000vr4tt
Sep 7, 2015 12:48 AM
