High Idle problem
Old Sep 5, 2006 | 05:38 PM
1fastsedan's Avatar
High Idle problem
I cleaned my throttle body and my car now idles at 1000rpm. i reset ecu using the (key on w/ gas pedal push 5sec method) but i still have the problem. when i drive and engage the clutch or put into nuetral the rpm bounces up to around 1500 then drops to 1000. this is very frustating driving under these conditions. can i make adjustments to the idle myself or is it solely controlled by the ecu. 2003.5 sedan 6mt
Old Sep 5, 2006 | 05:53 PM
DaveB's Avatar
Sounds to me like you disconnected the TB during the cleaning. If so, you need to do the throttle-by relearn procedure. Resetting the ECU won't help in this case.
Old Sep 5, 2006 | 05:57 PM
Jeff92se's Avatar
Red Card Crew
I also asked if he did this.
Old Sep 5, 2006 | 06:15 PM
ttrank's Avatar
Grocery getter
^^+1
The only way to adjust the TB is with a Consult tool that the dealer has. I would bet the TB learn procedure will fix it.
Old Sep 5, 2006 | 06:16 PM
1fastsedan's Avatar
how do i do this TB learn feature. is this dealer only?
Old Sep 5, 2006 | 06:23 PM
Jeff92se's Avatar
Red Card Crew
Did you disconnect the thing or not? I believe there are some OBDII scanners that can perform this idle learn procedure but in your case, it might as well be a dealer only thing.
Old Sep 5, 2006 | 06:46 PM
Msedanman's Avatar
O.F. Administrator
Along with a basic reset of the ECU, there are several other resets to do:
1) Accelerator Pedal Release Position Learning
2) Throttle Valve Closed Position Learning
3) Idle Air Volume Learning (Throttle Position Learning)
You can read about the procedures here in our FAQ/DIY forum, and scroll down to MERLIN's post.
VARIOUS ECU RESETS
G/L with the effort.
Colin
Old Sep 5, 2006 | 06:55 PM
driguez's Avatar
or just do the ol'12 hr disconnect
1fastsedan's Avatar
yes it was disconnected. the TB came completely out of my car.
Old Sep 5, 2006 | 07:21 PM
1fastsedan's Avatar
the various ecu resets seems to be vary helpful, i will give this a shot tonight.
Old Sep 5, 2006 | 11:01 PM
1fastsedan's Avatar
check engine light came on and the code was idle control? will one of the ecu resets fix this problem?
Old Sep 5, 2006 | 11:05 PM
driguez's Avatar
the one time that i cleaned my TB i was getting that same code with the same symptoms, tried clearing up the code with the pedal reset with no luck, the only thing that worked for me was he 12 hr disconect, all i can tell you is to try it tonight, wont hurt
Old Sep 8, 2006 | 12:24 PM
1fastsedan's Avatar
the 12hr disconnect worked, everything is back to normal!
Muski_G
Dec 1, 2023 11:11 AM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
