manumatic
Old Jan 13, 2007 | 12:12 AM
toymachine2009's Avatar
manumatic
what do you all think about driving full time in manumatic i have a 2005 sedan and i heard it can be bad for your engine if you do it full time then i also heard it wont do anything to you if you do it full time.
I would like to drive manumatic full time but if its going to mess up my engine or anything in my car i wont take that chance? your thoughts on this since i know nothing about the subject?
Old Jan 13, 2007 | 12:54 AM
lexusk8's Avatar
There a whole other long thread discussing about this a while back:
https://g35driver.com/forums/g35-sedan-v35-2003-06/126620-those-who-use-manumatic.html
Old Jan 13, 2007 | 01:07 AM
thanks for that thread but just a quick question tho when im coming to a red light and i start downshifting and slowing down the rpms rev up is this a bad for the engine at all or just normal?
Old Jan 13, 2007 | 01:27 AM
g35sedan5at's Avatar
it was designed to do that...called rev-match downshiftting
Old Jan 13, 2007 | 02:08 AM
maj83's Avatar
lazy a$$
I don't think my '04 has a rev-match feature. It doesn't downshift smoothly compared to the '06 sedan loaner I drove. Kinda sucks...
Old Jan 13, 2007 | 10:00 AM
only 05-06's have the rev-matching
Old Jan 13, 2007 | 10:37 AM
sliderg35's Avatar
I have an 03 and have been driving exclusively in MM since I got the thing 4 years ago. I woudln't drive it any other way.
Old Jan 13, 2007 | 11:13 AM
Desert_Fox's Avatar
^ same here on my 03
Old Jan 13, 2007 | 12:25 PM
EZZ's Avatar
EZZ
The 03 sedans had a less aggressive manumatic mode. It was actually a top gear selector meaning if you set it in 4th, the car will upshift automatically as if it was in full-auto mode until 4th gear and proceed to hold it in that gear. There was a later revision in the 2004.5 models to make it like the manumatic in the coupe...you manually have to upshift every gear. I've driven 2003 sedans for loaners and I always felt that the manumatic shifted less aggressively in those models. The manumatic in my coupe changes each gear much more aggressively. I feel like it causes more wear and tear. But the auto trannys are strong so longevity shouldn't be an issue.
mikeee2
Aug 30, 2005 12:27 PM
fullofivy
May 3, 2005 04:41 PM
chinee
Apr 1, 2004 02:49 AM
gtxjoe
Drivetrain
Mar 16, 2004 01:49 AM
suprhulk
Feb 27, 2003 03:26 AM
