Warning light near engine temp gauge
Old Nov 4, 2007 | 02:28 PM
Granto86's Avatar
I got in my car this morning and turned it on and first noticed that the temperature gauge of the engine was very low and taking a long time to increase, also, there was an exclamation point next to the gauge as well.. Does anyone know what this might be?
Old Nov 4, 2007 | 02:33 PM
alphamatt's Avatar
is it enclosed with to parenthesis ? (...!...)? thats your Tire Pressure Monitoring System (TPMS) its porbably a lil low, it can get annoying at times, when its cold the air in your tires loses pressure, when its hot it goes back.
Old Nov 4, 2007 | 02:34 PM
Granto86's Avatar
Yes it does have parenthesis, so should I do anything about it or leave it alone?
Old Nov 4, 2007 | 03:05 PM
toymachine2009's Avatar
all you have to do is check the pressure in your tires.. If they are really low just fill them up.
Old Nov 4, 2007 | 03:08 PM
Granto86's Avatar
Okay, the pressure should be at 35psi in all the tires correct?
Old Nov 4, 2007 | 03:18 PM
sloppymax's Avatar
my manual says 33psi for the 18s. not sure about the 17s if that what you have. make sure you are checking/refilling them when the tires are cold.
Old Nov 4, 2007 | 03:20 PM
Granto86's Avatar
Cold as in.. havent been driving on them for an hour or actually cold, cause, im living in miami so its tough to get my tires.. "cold" ha. And yea, i'm rockin the 17s
Old Nov 4, 2007 | 03:28 PM
sloppymax's Avatar
check your driver door jamb, the pressure will be listed on a sticker there. cold as in have not been driven in 4 hours or so and not sitting directly in sun. i check mine in the morning as the car has sat garaged all night.
Old Nov 4, 2007 | 04:52 PM
psedog's Avatar
Back in SD**
The 17's are 30psi. Even though though the dealer always fills them to 35psi.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
TWASkyliner
Aug 1, 2015 11:43 AM
ClwMike
Jul 23, 2015 12:55 PM
mjfenix
Jul 17, 2015 02:07 PM
