Anyone have this problem with their AT? Tranny acting strange
Old Jan 28, 2008 | 02:55 PM
SLVR JDM's Avatar
Over the weekend, I pulled a redneck move and did some tire spinning from a stopsign, nothing major - went through gears 1 & 2 in manual mode (VDC off).
After I had my jollies, I put it back to VDC on and into auto mode (at this point still in 2nd gear). It didn't want to shift into a higher gear (3rd or 4th would have been appropriate). I went ahead and put it back into manual mode and try to shift it myself (displaying 2nd gear at this point). After a couple of tries, it finally went into 3rd....tried the same thing for 4th with no luck. I came upon a few more stopsigns and put it into auto mode again. Everything seemed ok until I got to the onramp of the highway.....wouldn't shift out of second (in auto). I popped it into N for a second (didn't touch the throttle), then back into D. Seemed ok after that.....but dang, what is the deal with this thing?
I've only had one other incident involving the tranny. Basically that time I was doing a few donuts in some snow (VDC off). When I got done, I couldn't turn the VDC back on.....and the slip/traction light stayed on. I turned the car off and back on....was fine after that.
Anyone else have odd situations like this? These are the only two times I really had any fun with VDC off.....makes me not want to do it again.
Any thoughts?
Old Jan 28, 2008 | 02:57 PM
crashnburn's Avatar
check ur tranny fluid level... i was low on tranny fluid once and it did that
Old Jan 28, 2008 | 03:20 PM
SLVR JDM's Avatar
I'll give it a look when I get home tonight...thanks for the suggestion.
Old Jan 28, 2008 | 11:19 PM
marty315's Avatar
I found your problem:
Originally Posted by hoenignd
I pulled a redneck move and did some tire spinning from a stopsign.
You reap what you sow. You want a redneck car, buy a Camaro or Mustang. Otherwise, take care of your luxury sedan and it will take care of you. Case closed.
Old Jan 28, 2008 | 11:27 PM
Neal376's Avatar
+1 ATF is usually the case
Old Jan 29, 2008 | 11:39 AM
SLVR JDM's Avatar
Thanks for your opinion....little uncalled for. This isn't exactly a frequent activity of mine, so the car should be able to take it. If not, I need to look for a better car.
Old Jan 29, 2008 | 02:32 PM
DaveB's Avatar
The VDC issue is completely normal. I'd imagine with other issue you had was normal too because it sounds like you completely spun the tires through 1st and 2nd. This may have been enough to cause the tranny ECU to go into safe mode to make sure you didn't damage the tranny.
Old Jan 30, 2008 | 10:47 AM
SLVR JDM's Avatar
Good thought, I wasn't aware that our cars had a safe mode.....guessing this is something like BMW's "limp home" mode, which prevents damage (I'm a little more familiar with that). Thanks for the feedback.
Old Jan 30, 2008 | 11:33 AM
68_GT's Avatar
ha ha no **** man. Otherwise why is there a damn button to turn the VDC off ? I call that button my fun button I drive my car pretty hard Hopefully it will take it. I drove the **** out of my 2000 GT Mustang and put a paxton blower on it at 113,000 miles and it lasted another 15K miles on moderate boost until my radiator crapped out in Houston traffic and cost me a headgasket. If this import car/ motor can't do at least that well I'll never buy Nissan or Infiniti again.
Old Feb 14, 2008 | 04:42 AM
G35Drifter619's Avatar
ive been fully drifting my car for years. im 20 now and grew out of buying tires constantly but yeah pull your vdc chip and just drive safe. if u dont wanna damage the chip that is. i drove without mine for months. most people just pull it to have fun. i like driving hard in traffic it stops me from getting into trouble with other stuff. i have videos and err thing of my car getting buck.
Old Feb 14, 2008 | 09:56 AM
jonE5's Avatar
answer to all problems due to AT = 6MT
jon!
Old Feb 14, 2008 | 10:41 AM
chaindrive's Avatar
never had that happen turn car off then back on. probably confused the processor flipping vdc on and off while ******* the crap out of it.
Old Mar 27, 2008 | 10:43 AM
julioi23's Avatar
vdc off is a ton of fun, but i know that when i hit that little button my gas starts to plummet. it's like the car is exemplary when the vdc is on, but man when that little light says VDC OFF, i automatically develop a leadfoot!
snic09
Nov 8, 2017 01:46 PM
Jnm07
Sep 5, 2015 01:16 AM
pasjr1972
Sep 1, 2015 10:17 PM
03sedang35
Aug 29, 2015 07:56 PM
