TPMS stays "ON"
Old Feb 28, 2008 | 11:15 AM
yanky's Avatar
TPMS stays "ON"
Hi Guys,
i have 2004 infiniti g35.
The TPMS light stays ON forever.
i have checked pressure - 30 PSI, as it says on the sticker, have recently changed tires but kept the same factory rims, but the light still stays "ON".
Any suggestions??
Old Feb 28, 2008 | 11:19 AM
kvangil's Avatar
Perhaps a bad sensor, or a missing one if you just bought the car... For example, mine only has 3 sensors, because one broke, and I replaced it with a regular valve stem. It doesn't bother me though....
Old Feb 28, 2008 | 01:37 PM
G'ed in TX's Avatar
From what I understand the sensors are only supposed to alert if you fall to 25 psi or below, so sounds faulty to me...
Possible when they put on the new tires they replaced one of your rims with the spare, which even though is full size, has no sensor?
Old Feb 28, 2008 | 02:12 PM
geesteezd's Avatar
+1 on the faulty/missing sensors
mine were on, took it back to infiniti and they handled it..
Old Feb 28, 2008 | 03:00 PM
yanky's Avatar
i have an appointment next month with infiniti for 72k km checkup.
will let them know about it.
hope they fix it
i really do not like lights flashing infront of me in the console
Old Feb 28, 2008 | 03:18 PM
jonE5's Avatar
what happens if you get aftermarket wheels and do not move the sensors?
Will a light be on?
Old Feb 28, 2008 | 04:16 PM
Konsole's Avatar
Will a light be on?
Yes.
I have a set of painted stock wheels with no tpms. The light blinks for a few seconds than goes solid. I just ignore it and check my pressure every so often... old school.
Old Feb 28, 2008 | 04:27 PM
jonE5's Avatar
grrr, is there anyway to turn off the light? thats annoying
Old Feb 28, 2008 | 05:03 PM
G'ed in TX's Avatar
You'd have to trick the sensors and if they're valve stem type sensors you could only mount one on the spare, as oppoesed to other types of TPMS where you could insert them all on the spare to trick the light into going off...
Old Feb 28, 2008 | 10:12 PM
OCG35's Avatar
either a bad sensor or bad sending unit... it's not that uncommon... however, the dealer may take several attempts before fixing - took me 4~!
Old Feb 29, 2008 | 01:02 PM
apintojr's Avatar
well, when i put on my summer rims, my TPS light comes only after a good half-hour of straight threw driving on a highway. it will stay on till i shut the car off. if i'm doing regular city driving my TPs light never comes on.
Old Feb 29, 2008 | 01:59 PM
ttrank's Avatar
Grocery getter
It all depends on how long you are driving before it comes on. Mine takes about 30 minutes too.
KruZZe
Feb 27, 2023 05:04 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
