Code
Old Jul 7, 2008 | 12:35 AM
TOYSTA's Avatar
Code
Ok so my SES light came on.
Went to autozone to have it read, "Catalyst efficiency low-bank 2." Guy at autozone said I might need to change the catalytic converter. What do you guys think? anyone know where I can get one cheap?
Another problem....
"ECM power supply circuit- Back up RAM malfuntion" ??????
Old Jul 7, 2008 | 12:39 AM
dieselaznrock's Avatar
never had these problems but curious, so... bump
Old Jul 7, 2008 | 03:13 AM
gtbigup01's Avatar
Does it have anything to do with an exhaust mod
Old Jul 7, 2008 | 07:33 PM
Sonicbounce17's Avatar
some cat codes call for you to reprogram the ecm. its a situation based fix. it might not be much help or maybe common knowledge around here ive only been a member for a month.
possiable causes
three way cat
exhaust tube
intake air leaks
fuel injectors
fuel injector leak
spark plugs
improper ignition timing
if i werent so dumb i would post a picture i clicked the insert picture but i didnt show...i also didnt search to find out how
this is all for p0420 code soory if it doesnt help.
Old Jul 7, 2008 | 07:49 PM
TOYSTA's Avatar
possiable causes
three way cat
exhaust tube
intake air leaks
fuel injectors
fuel injector leak
spark plugs
Hmmm...well the code that I got was P0430. Don't know if it's a big difference. I haven't done any mods either.
Ok found the paper with possible causes
1. catalytic converter defective (failure possibly doe to #2, 3, or 4)
2. Engine misfire or running condition
3 large vacuum leak
4. engine oil leakage into exhaust valve guide seals, piston rings.
Old Jul 8, 2008 | 03:29 PM
P420 is bank 1
P430 is bank 2
some converters are covered 8 years 80,000 miles
if you give me your vin number i can check nissan.net for for information
http://www.motoralldata.com/alldata/...8411/132235432
i dont know if that link will work for you
Old Jul 8, 2008 | 08:42 PM
TOYSTA's Avatar
P420 is bank 1
P430 is bank 2
Eh, my car is a Salvage title, don't think it would work. But hey, I did reset the ECU yesterday and passed emissions today..
Old Jul 9, 2008 | 09:44 AM
good to hear
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
