TUcked in or NOT :bowrofl:
Old Nov 26, 2008 | 07:27 AM
iiiiiekoiiiii's Avatar
im going to be a noob for a little.
would 2005-06 g35x with H&R sedan or COupe springs tuck the OEM rays 19s under the rear fender.
Thats all. Got a little project on my mind but before I pull the triggger thought I shall ask. =]
Pix would be appreciated.
Old Nov 26, 2008 | 08:49 AM
tucked in or not
Old Nov 26, 2008 | 10:30 AM
Texasscout's Avatar
Would the top of the tire be UNDER the fender well? Is that what you mean? I think it would. I have 350Z springs and the top of the back tire is about 1/4" from the bottom of the fender well. H&R should give you almost 2" of drop. so they should be under the well.
Now we may have two different definitions of the word "tuck". When I say tuck, to me, it means negative camber that you must apply to the suspension to get eh wheels to just fit in the fender wells after you roll them.
This is an exaggerated tuck on a VIP car:
Old Nov 26, 2008 | 10:33 AM
Texasscout's Avatar
This car is hella tucked:
Old Nov 26, 2008 | 12:24 PM
ttrank's Avatar
Grocery getter
G35 sedan springs on your X would be about perfect IMO. Should be right at the top of the tire all around.
Old Nov 26, 2008 | 01:05 PM
blklude98's Avatar
350z front springs on G35 sedan sport suspension, G35 coupe Rear springs/shocks. Car is a G35 6speed. Tires are 225/40/19F, 255/35/19R to give you an idea on how it should look on your car.
Hope that helps
Old Nov 26, 2008 | 02:04 PM
G35MTK's Avatar
I just got H&Rs Installed. Ill go take pictures for you (granted they havnt settled all the way)
Old Nov 26, 2008 | 03:38 PM
Kazaam's Avatar
I have the H&R's on my 05X with koni sport yellow shocks, and it's perfectly even all around. One finger maybe even more in the back.
Old Nov 26, 2008 | 05:20 PM
FutureGDriver's Avatar
im currently running staggerd 18 inch coupes with Eibach Sportlines and thats the lowest iv'e seen for springs also ran it with my 20 inch staggered with 20x10 in the rear which tucked a little more than my 18's.
Attached Thumbnails TUcked in or NOT  :bowrofl:-sd.jpg   TUcked in or NOT  :bowrofl:-tw.jpg
Old Nov 26, 2008 | 07:03 PM
THanx guys,
Yes, exactly What I was askin for.
Since X cant change the front struts. ( we're limited to just change of springs in the front. )
TTRANK, I dont think g35 sedan springs would do me anygood. I like gettin low =] probbly sedan H&Rs or Coupe H&Rs to keep the ride quality and a bit stiffness.
kazaam ur car looks a bit 2 low for the rims since the rims dont have a huge lip to make up for it, it looks like car is saggin.
blklude98, I like the drop, almost perfect maybe another finger on the rear, and it's set.
I might go with sedan sport rear shocks with H&Rs....
anything u guys think let me know =]
Old Nov 30, 2008 | 03:16 PM
maxspeed96ct's Avatar
I had slight rubbage with oem rays on stock bridgestone 245's when on My TEIN S-Tech.
Look into fender rolling or a smaller tire if you want to tuck..
BTW i have some stock g35 sport sedan springs laying around i can sell you.
Old Nov 30, 2008 | 05:27 PM
Texasscout's Avatar
I just got new wheels and tires, they came out perfect. No rubbing and the perfect distance from the fenders.
Check it out:
https://g35driver.com/forums/check-o...-dg-sedan.html
Old Nov 30, 2008 | 07:53 PM
snotf's Avatar
Kazaam, you should open up your headlights and tint the turn sigs... really brings the black look out.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Kelvin Style006
May 23, 2016 03:47 AM
Derekb
Sep 21, 2015 05:29 PM
crakke
Sep 1, 2015 04:23 PM
Soumilg
Jul 18, 2015 12:33 PM
