Need Help Quickly! Lowering 06 X!
Old Mar 8, 2009 | 01:49 PM
Wannabe6MT's Avatar
-MN G Crew-
On the front of an 06 X, how the heck do we get the spring assembly out? it is like there is a clamp or somthing at the bottom that we cant pull the bottom of the strut assembly out of.
Anyone hav epics or some helpful advise? this is different than the RWD...
Old Mar 8, 2009 | 02:17 PM
DaveB's Avatar
Make sure you've got the entire front end jacked up, not just the side you're working on. You'll need to disconnect the swaybar endlinks on both sides before preceding. You'll also have to press down a bit on the rotor to push the assembly down to get the spring/shock out. Finally, post pics of the area you're having trouble with.
Old Mar 8, 2009 | 03:42 PM
FlyingLumpia's Avatar
Unscrew the nut on the bottom of the arm. Take the whole thing out. It will be easier then.
Old Mar 8, 2009 | 03:45 PM
also what Dave said too.
Old Mar 8, 2009 | 04:01 PM
Trbulnt's Avatar
I followed exactly how pictured above and it is very easy. The stock front spring takes alot of force from the spring compressor to relieve the tension so please be careful. Also make sure you remember how the top bearing plate is on in association with the arm.
Old Mar 8, 2009 | 06:37 PM
Wannabe6MT's Avatar
-MN G Crew-
We had an issue getting it lined up with the top bearing plate. but eventually got it in.
Looks great.
Old Mar 8, 2009 | 09:16 PM
Lucky-G's Avatar
Ttiwwp!!!!
Old Mar 8, 2009 | 09:19 PM
Wannabe6MT's Avatar
-MN G Crew-
Pics in the lowered X section of the car we were working on!
g.spot
May 9, 2016 10:54 PM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
EasySausage
Sep 24, 2015 01:06 PM
mattdg35
Sep 14, 2015 11:28 AM
