Front Camber for 2004 sedan...need help deciding which one to buy
Old Jan 26, 2010 | 05:57 AM
gq916's Avatar
Looking for a camber for the front. Tired of tires going bald on the inside every 10k miles.
I found one on ebay brand new for $150 shipped (link below). Doesnt really say the name of the brand. Should i buy this one? or a different one? and how hard is it to install?? THanks
http://cgi.ebay.com/ebaymotors/Nissa...Q5fAccessories
Old Jan 26, 2010 | 09:22 AM
FlyingLumpia's Avatar
No, Yes, and No.
Old Jan 26, 2010 | 02:49 PM
OCG35's Avatar
there is so much info in the suspension section...
Old Jan 26, 2010 | 05:53 PM
gq916's Avatar
Originally Posted by FlyingLumpia
No, Yes, and No.
why shouldnt i buy it
Old Jan 26, 2010 | 07:27 PM
davidxu's Avatar
because you dont want anything to happen to the things that are between your car and the wheels supporting it..... you really want your wheels to come off at highway speeds?
ebay + mod = fail
buy the SPC camber kit.
btw, use the search button... this question comes up almost everyday
Old Jan 26, 2010 | 07:30 PM
OCG35's Avatar
OP - here's is a current thread on the topic... you should be in the suspension section with this question...
https://g35driver.com/forums/brakes-...mber-arms.html
Old Jan 26, 2010 | 08:23 PM
4DGS's Avatar
SPC or just burn the tires.
Would you trust your car on the cheapest brakes and brakes lines in existence?
Old Jan 27, 2010 | 03:03 PM
gq916's Avatar
no i wouldnt trust my car with the cheapest brakes, better brakes are made out of better material.
When it comes to camber are the expensive ones made out of better material? some of them look the same, Im trying to figure out the difference. between the $150 one to the $300.
I cant believe camber is so expensive for these cars, its ridiculous ! stillen sells theres for 850 !! holly cow. spc for $400 ! they are way too overpriced. A good camber kit shouldnt be more than $200.
Old Jan 27, 2010 | 03:09 PM
4DGS's Avatar
^process of making them probably isn't as good. Might have flaws in the build and cause them to crack. Lots of little things could go wrong, or nothing at all.
I would rather spend the money once on the right stuff then spend it twice on the wrong.
Old Jan 27, 2010 | 03:15 PM
gq916's Avatar
i see what you are saying. I might have to buy SPC or ichiba. What do you think about ichiba? and how long will it take to install at home?
Old Jan 27, 2010 | 03:21 PM
4DGS's Avatar
Ichiba is a great company, I've never dealt with their camber kits though. Everything else they make is top notch though.
Depends on your knowledge of suspension parts, anywhere from an hour aside to 2 hours. If you know what you're doing it's pretty quick, but take into consideration you probably don't have a lift. If you had a lift, it's a breeze. Which is why I have my custom guy the majority of my work, I'm just not in the mood to jack it up ever.
Old Jan 28, 2010 | 11:37 AM
GSedan03's Avatar
i have spc on my car now and they do the job, no complaints. its expensive just because its not a honda or toyota, its a infiniti, what isnt expensive =D
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
