Tune up Questions
Old Mar 23, 2010 | 11:01 PM
gameover's Avatar
Tune up Questions
Does these cars have a transmission filter..Having trouble finding one at the parts store.. Does it have a fuel filter??
Old Mar 23, 2010 | 11:47 PM
Tollboothwilley's Avatar
SEARCH. I know this is your first post.
Stick around, but next time you should do a search on it and you'll find tons of info.
No, there is not a serviceable filter...for either the tranny or the fuel.
Old Mar 23, 2010 | 11:49 PM
gameover's Avatar
Sorry... Thanks for the info..
Old Mar 24, 2010 | 12:09 AM
no worries. I just thought i'd let ya know before everyone flamed ya
There is a lot of info and almost any question you have has been asked at least 5 times. Keep that in mind and search will be a good friend.
Old Mar 24, 2010 | 07:45 AM
sloppymax's Avatar
The transmission has a mesh screen that could be cleaned with brake parts cleaner or something similar. It should only be replaced if the mesh is torn. As for the fuel filter, I will be replacing mine around 50k miles. It is attached to the fuel pump assembly in the tank under the back seat. My last Maxima had the filter in the same location and it was caked with sediment at 50k even though I always used top tier gasoline.
Old Mar 24, 2010 | 11:05 AM
OKStateG35's Avatar
Is this difficult to change? Also, any ideas on a part number?
Old Mar 24, 2010 | 11:34 AM
sloppymax's Avatar
I think it took about an hour and a half. Only do it with less than a 1/4 tank of gas. I pulled the fuel pump fuse then started it until it died to relieve fuel pressure. I think it cost about $18 plus 7 for shipping from Courtesy Nissan back in 2005. I tried finding the part number for the filter/screen for the Z on the Courtesy site but cannot locate it now.
Old Mar 24, 2010 | 11:53 AM
OKStateG35's Avatar
Thanks. I might try to change out the fuel filter this Summer when I do my other 60K maintenance.
Old Mar 24, 2010 | 02:33 PM
blazeplacid's Avatar
top tier doesnt mean its clear of all dirts and sediments.
Old Mar 24, 2010 | 02:36 PM
sloppymax's Avatar
I realize that. Just wanted to point out I was not filling up at mom & pop's gas with no discernable origin with 40 year old tanks. Just stressing that the screen could be replaced with favorable results even with using newer stations that carry higher tier gasoline.
jsimonk
Dec 22, 2023 03:49 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
