rear camber
Old Apr 15, 2010 | 04:43 PM
SN00P's Avatar
CLUB MODERATOR
rear camber
as you guys know my drop was 2.5'' and i only have about a pinky gap in the rear from tire to my fender .. im going to order the SPC camber kit this weekend for my car ... i have done some research and found a few thing about camber and toe .. yes i know im going to need adjusting but my question is b4 i start eating tires let and right i want some opinions on where to get my camber number at in the negatives ... and the toe at ... thanks in advance for the help guys ...
here is what im dealing with here is a little picture ... i do not know what camber number i am currently at .. im think -4 ??? i dont know if this is a good picture for help if not lmk of a certain picture angle and ill post it up for some help
Old Apr 15, 2010 | 04:49 PM
Matzo Ball's Avatar
I am on S-techs and camber is at -2.8* w/o my camber kit installed. Stock for the X is at 1.6-1.8*
Old Apr 15, 2010 | 05:08 PM
SN00P's Avatar
CLUB MODERATOR
what should my camber be at if i order the SPC kit ..
Old Apr 15, 2010 | 05:16 PM
Jeff92se's Avatar
Red Card Crew
I understand if english is not your 1st language but it's "know" not "no" for examples like "I don't know"
As far as what you should be at, that's up to you. You can try to get it back into G sedan specs, go for 350z specs or more/less
Old Apr 15, 2010 | 05:27 PM
SN00P's Avatar
CLUB MODERATOR
i corrected it english teacher lol
my only concern is of how close i am to my fender as it sits now without a camber kit .. like i said im close to 1/8'' gap for tire play from rubbing .. how much closer can i correct my camber if I'm already that close ..
Old Apr 15, 2010 | 05:28 PM
Jeff92se's Avatar
Red Card Crew
thatsgreatandwonderfulforyouihopeithelpsyoulaterin life
Old Apr 15, 2010 | 05:34 PM
SN00P's Avatar
CLUB MODERATOR
^^ did you want me to correct that for you , I think your space bar didn't work till the last word
Old Apr 15, 2010 | 05:37 PM
Jeff92se's Avatar
Red Card Crew
yespleasecorrecti4methanksdidntyounos?
Old Apr 15, 2010 | 05:42 PM
The Stimulation's Avatar
I'm a tad confused. What's the issue? I'm assuming you're trying to dial in some positive camber? To be honest it doesn't seem like you got much room to play with. Adjust half a degree or so is not worth buying a camber kit for, hard to tell with that pic.
I'm all for going the inexpensive route. I'd say get some toe bolts and just get the toe in spec. From the pics it looks like you would barely clear as it is so adding some positive camber would cause you to rub.
Old Apr 15, 2010 | 05:43 PM
Matzo Ball's Avatar
you will probably get back to around -2.0* Are your fenders rolled? You should be fine. I am probably going to put a 5mm spacer out back once corrected and should have no issue.
Old Apr 15, 2010 | 05:48 PM
SN00P's Avatar
CLUB MODERATOR
that is correct i no we have some room with stock camber adjustment but not a whole lot .. I'm thinking i can at least get that close and just get the toe bolts and get that on spec .. thats pretty much all i can do correct
Old Apr 15, 2010 | 05:50 PM
SN00P's Avatar
CLUB MODERATOR
my fenders are cut ... i wish i didn't go so low that way i can get the camber back in spec and throw some spacers on the rear ...
i will go and take a picture from the ground up to show you a better view
Old Apr 15, 2010 | 05:53 PM
cremaster's Avatar
just curious, why did you cut the fenders? i've always thought that was a bit extreme.
If your fenders are cut, that will help quite a bit. You can pull the fender to add more positive camber too.
Old Apr 15, 2010 | 05:56 PM
SN00P's Avatar
CLUB MODERATOR
the reason is because there are very few shops that offer to do this like 1 or 2 .. one place wanted 85 a hr and said it would take 2.5 hrs so that was deff out of the question after i read on here and everywhere is like 100 bucks and the other place didnt seem to no what or that confident about rolling it and i deff not need paint chipping or anything like that ...
+ i got more cut out of the rear and more room then i would have with a fender roll unless i got it flush but the shops here wouldn't do that but only i mild roll
