Squealing noise....
Old Jul 7, 2010 | 02:21 PM
neptune's Avatar
Squealing noise....
Hi, I have a 2006 sport sedan 6MT.
There's been a squealing noise from the front of the car for a while. Seems to be there no matter if its hot or cold outside or wet, etc. The noise is usually consistent from when the car is started to shut off, even on longer drive.
To me, it sounds like belts, but I'm not sure. What belts does this car have? Just a couple of drive belts or something more / different?
Any recommendations on what to replace these belts (or other parts) with?
Thanks!
Old Jul 7, 2010 | 03:08 PM
socialconflicts's Avatar
from what i have heard in my other car i had, its probably belts. it has 2 belts which u can see if u lift up your hood. buy them from riverside infiniti they sell em for like 36 bucks the pair... but first verify the problem is coming from the belts
Old Jul 7, 2010 | 03:12 PM
thescreensavers's Avatar
Mr.202?
Does it sound like this
Replacing the belts will fix that
Old Jul 8, 2010 | 12:13 AM
tonke73's Avatar
Open the hood, pop your head in and check the tension on the belts. The belt tension should be tight with zero slack. If your belt(s) are loose, and are still in good shape, you can tighten the slack on the belt. There may be a DIY on how to do that. There is a long adjustment screw attached to one or more pulleys that you use to remedy the squealing.
Old Jul 8, 2010 | 10:03 AM
neptune's Avatar
Thanks tonke. I'll try that and see how it feels....
Old Jul 8, 2010 | 10:06 AM
PAIXAO's Avatar
If they're not cracked or in need of replacement, just adjust the tension on them.
Old Jul 8, 2010 | 11:10 AM
socalwdup's Avatar
Ooh I have that too
Old Jul 8, 2010 | 12:51 PM
VQEric's Avatar
2 belts - 1 narrower belt for A/C compressor, 1 wider belt for alternator and power steering pump. If the squealing starts or worsens when you turn on the A/C, then the A/C compressor belt is the one to tighten or replace depending on condition. If not, then it's *probably* the other belt.
Also, be careful not to overtighten the tensioner pulley adjustment bolt past its limits of travel. It is made of some pretty soft metal and will bend easily, rendering it useless. Ask me how I know! If you have to adjust it that far, then the belt is probably stretched too much and needs to be replaced even if it looks good.
Old Jul 22, 2010 | 08:05 PM
AzWildcatG's Avatar
I have had a engine squeal for a few months. The interesting thing is that is does not squeal in "park", but once my G gets shifted into "reverse" or/then "drive" the squeal begins. The dealership said that it needed to go on the diagnostic machine for $125 to find my G's problem. BS. I am sure that they know what the problem is, but want to stick me for a few extra $$$. Thoughts???
BTW, just had my first brake job done last week. My G has 51K and the weird thing was that the rears were in need of replacement. The guys at Goodyear Gemini said that the fronts were still in great shape.
Old Aug 29, 2010 | 02:35 AM
GPL777's Avatar
I have a squealing problem now. As you rev up the engine it gets louder. Sound like it's coming from the pulleys. Sound almost like a loose belt but not as loud. Haven't change the belts since 35k as now it is at almost 80. Any advice is appreciated. thanks.
3000vr4tt
Sep 7, 2015 12:48 AM
G35CO
Aug 25, 2015 02:00 PM
Patrick952
Oct 29, 2005 04:51 PM
live2ski
Nov 8, 2004 08:19 AM
rmeaux
Sep 26, 2003 05:54 PM
