Random Little Question Thread
Old Feb 14, 2011 | 09:27 AM
  #2986
CG4DR's Avatar
^you can use a 194
Anyone use Nippon lug nuts before?
Old Feb 14, 2011 | 12:31 PM
  #2987
OCG35's Avatar
Doesn't Nippon make cup o noodles or ramen or something?...
Old Feb 14, 2011 | 01:13 PM
  #2988
G35Papa's Avatar
^That's how you can tell it's authentic JDM yo!
Old Feb 14, 2011 | 10:37 PM
  #2989
VincenzG35's Avatar
Lmao!!!!
BTW anyone have a pic with LED 194's in the sedan headlight with or without 6000ks
Old Feb 14, 2011 | 10:58 PM
  #2990
D.Reaper's Avatar
I have a question, i notice everytime i take my car out for the first time after warming it up, it seems to grind as it switches between 1st to 2nd...after that first grinding sound, it goes away...any ideas on what is causing this?
Old Feb 15, 2011 | 02:17 AM
  #2991
thescreensavers's Avatar
Mr.202?
its this
Old Feb 15, 2011 | 08:00 AM
  #2992
D.Reaper's Avatar
^ thanks man, that defnitely sounds like it...i was always afraid it was my tranny grinding
Old Feb 15, 2011 | 09:16 AM
  #2993
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by thescreensavers
Good find Danny. It's pretty hard to describe how it sounds, but this nails it.
Old Feb 15, 2011 | 12:17 PM
  #2994
D.Reaper's Avatar
so i should be picking up some wheels tonight, just wanted to confirm all the specs sound like they'll work : 19x8.5 +40 and 19x9.5 +45 with i believe 245/35/19 all around
Old Feb 15, 2011 | 12:20 PM
  #2995
Wannabe6MT's Avatar
-MN G Crew-
Saw this in DC lol
Old Feb 15, 2011 | 01:19 PM
  #2996
DrewLe's Avatar
^Wow! I'm surprised somebody even bought that sticker.
Pretty funny though.
Amazon Amazon
Old Feb 15, 2011 | 02:08 PM
  #2997
barbereno's Avatar
Thanks for your (forum) help on paint and headlights. I am in need of a window motor and was wondering if I should be worried about the ebay motors listed for around $190. Also, my factory sub is not on at all. I took down the small amp on the back deck and found no fuse or switch. I have also checked all three fuse boxes and am still unable to locate a fuse for the amp for the sub. I found two fuses listed as "radio" but both are good.
Old Feb 15, 2011 | 02:23 PM
  #2998
barbereno's Avatar
I have a couple of headlights for sale. Both are OEM with the HID. One (driverside) is cloudy. The other is in great shape. I was going to sell them on ebay but, this site has helped me out several times and I would be willing to sell for cheap. Im in Melbourne, FL.
Old Feb 15, 2011 | 04:36 PM
  #2999
Mr.202?
Yep, Thats my video I made it a bit ago just to suffice peoples question on this topic
Old Feb 15, 2011 | 04:40 PM
  #3000
dahlqje's Avatar
suspension
i have seen tons of stuff on lowering and springs and specifically some posting spring rates. What is the source of some of the numbers. In particular, some are advertized as progressive. that implies a a nonlinear spring rate like the first in is 300 lb/in but the second inch may be 330 lb/in. I alos dont see the spring "free lenth" listed. these are both impotant in calculating the drop. any takers here?
Another related issue is the Tire/Wheel weight, spring weight, the effective spring rate of the tires, and damping ratio of the shocks/struts. i dont see that info either. Any takers here?
Ok to make this more simple, has anyone changed to just a lighter wheel and tire combination to se how it affected the ride and handling. Did it matter more than having wider(heavier) tires on the back?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
