Random Little Question Thread
Old Mar 24, 2011 | 11:32 PM
  #3331
CandlestickPark's Avatar
ill Sedan
Originally Posted by ilv2xlr8
His car is not BS though. His car looks likes Serengeti Sand. It has to be someone elses'
That is Flying Lumpia. That shot was taken by Calvin during our Ultimate G35 Sedan Photoshoot in 2009. His car is DP.
Old Mar 24, 2011 | 11:42 PM
  #3332
ilv2xlr8's Avatar
I guess it's the lighting. The pics I've seen taken by Flying Lumpia look like the car is a different color. Regardless, ridiculously clean and perfect stance IMHO. I wonder what he was dropped on during that picture.
I know those wheels are discontinued and a bit difficult to find. What are the closest wheels to those? VSXX?
Old Mar 25, 2011 | 01:03 AM
  #3333
G35Papa's Avatar
Originally Posted by NFSP G35
The other question I had...
If I change my rear indicators to LED but the fronts are still incandescent, will I still need load resistors?
Nope, you should be fine. From what I've experienced, when you start swapping to LEDs on more than one circuit (i.e. headlight blinkers and tailight blinkers) that is when you get the hyper blink. I have it now and need to figure out (or just wait for my friend to tell me what to do ) as I can't seem to get it blink at normal speed when the lights are on...regardless if I add a load resistor.
Old Mar 25, 2011 | 01:11 AM
  #3334
NFSP G35's Avatar
? = 2B || !2B
^Cool. Thanks
Old Mar 25, 2011 | 07:25 AM
  #3335
TurTLe*'s Avatar
he is dropped on BC coils. But he has modded them, with a different type of spring from what i read, i'm not sure what the setup was in the pictures.
VSXX looks close to me, i dont see silver much tho, the gold ones and burning black are more common.
Old Mar 25, 2011 | 09:58 AM
  #3336
FlyingLumpia's Avatar
Yes that is my car. In that pic I am on bc racing, the spring were not swift at that time but were 12k from bc. As for the wheels yes they are algernon intelesse 19x9 +32 and 19x10 +32 but I had a 10mm spacer in the pics. Also it could have came down in the back alittle more that day.
You can find those wheel on a site called Memory fab or vr motorsports. They buy and sell rare wheel. They wont have the offset the same as mine. Here is a set Memory fab is selling.
http://www.memoryfab.com/wheels/used/20100624165009
But they are 19x8 and 19x9.5 +44 and +45 kind of week.
and at vr wheels they have these which are the same color in my pic (i have change the color)
again the spec are pretty weak if you want to run a semi aggressive set up.
Old Mar 25, 2011 | 11:44 AM
  #3337
Matzo Ball's Avatar
How many times can/should you unmount/remount wheels using the same tires. I have had 3 sets of wheels on the same tires and looking at number 4. I really dont want to screw mine tires up a I have alot of tread life left.
Old Mar 25, 2011 | 01:04 PM
  #3338
TurTLe*'s Avatar
there really is no limit. well maybe if your stretching the tire. But when you mount the tire, sometimes they dont balance right, so you gotta redo everything. But i wouldn't worry about it if your not stretching it. If you are im pretty sure it shouldn't matter but i never mounted/balance repeatedly these tires.
I've flipped many tires around mainly cause of camber just to even them out back and fourth and never thought twice
Old Mar 25, 2011 | 02:05 PM
  #3339
Matzo Ball's Avatar
thank you, sir
Old Mar 25, 2011 | 03:14 PM
  #3340
Wilg35j's Avatar
Hey guys where can i buy a lisence plate delete for my 03 sedan???
Old Mar 25, 2011 | 04:37 PM
  #3341
NFSP G35's Avatar
? = 2B || !2B
^Check the marketplace. They pop up from time to time.
I've all seen them on eBay.
You could also watch around the forum for any 03/04's upgrading bumpers and PM them about selling their old one.
Old Mar 25, 2011 | 05:10 PM
  #3342
OCG35's Avatar
Nail'd it.
I have these right now:
The beam dispersion is 100% perfect, I just don't want the yellow cast in the sunlight.
I'm afraid switching to LEDs will make throw off the beam pattern since I have them behind projectors.
Right now it's all nice and perfectly even because all the light is coming from one filament, instead of a cluster of smaller light sources.
Make sense now?
the PIIA Chris and I mentioned are incandescent, not LED... no yellow cast, but illuminate amber... most people that have clear turn signal lenses use them.
If you are interested in the part number, let me know - I have the original box in my garage... or someone else might already know the part number (Chris, Marcus, or ?)
As for resistor in the rear = yes afaik
Old Mar 25, 2011 | 05:12 PM
  #3343
OCG35's Avatar
Looks like the result of the lighting/white balance.
Notice how much more purple the taillights look?
they are EDM
Old Mar 25, 2011 | 05:15 PM
  #3344
NFSP G35's Avatar
? = 2B || !2B
^Thanks Mike.
I think I'm going to get the ones from Autolumination that I posted.
They're like the PIAA's in that they're silver finish but illuminate amber. But they're only $3.50/ea.
If they're good, I've saved some money. If they're crap, I didn't lose that much.
Old Mar 25, 2011 | 05:16 PM
  #3345
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by OCG35
they are EDM
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
