Random Little Question Thread
Old May 19, 2011 | 09:42 AM
  #3916
silver9's Avatar
I am thinking of running 245/40 (R) and 235/40 (F) on my stock sport sedan 18s. Good idea? They are currently 235/45s all around. Thanks in advance.
Old May 19, 2011 | 04:47 PM
  #3917
thescreensavers's Avatar
Mr.202?
does 10mm really matter?
You can run 245/45 all around or 245/40s
Old May 19, 2011 | 06:10 PM
  #3918
CG4DR's Avatar
Anyone dealt with DTCs p1148, p1168, p0031, and p0051?
Old May 19, 2011 | 10:39 PM
  #3919
kyemaul's Avatar
Recently dropped my g on megan coils and when i get on the gas or come to a slow stop im hearing a creeking broken bushing noise in the back left. would a camber kit fix or do i need something else back there?
Old May 20, 2011 | 01:00 AM
  #3920
xxxxxxxxxx's Avatar
does anybody know the length of the studs that come on the 15mm ichiva v1 spacers?
Old May 20, 2011 | 01:13 AM
  #3921
Mr.202?
Originally Posted by ilv2xlr8
Just got some tires from tireack rack: 235/45-18s Conti DW - DOT says 2109. Tires are basically 2 years old: Should I have them installed? Seems old to me. I also ordered a tire for my spare and it was 1711 so basically brand new.
Eh, I would stop using tires after 6 years, but its odd that tire rack sent you 2 year old tires, ask them about it
Old May 20, 2011 | 02:47 AM
  #3922
4DGS's Avatar
Sounds like worn out bushings lol
Does it happen when you're getting out or if you put weight in the trunk? I recommend replacing most the bushings back there anyways since it is an 03/04 and didn't spend it's time in the Cali sun (much like mine)
Old May 20, 2011 | 04:06 PM
  #3923
TheGThirty5's Avatar
Anyone know how much a used sports tuned suspension (red shocks)
run for?
Old May 20, 2011 | 06:39 PM
  #3924
4DGS's Avatar
I wouldn't spend more than $150 on them with low miles.
Anymore and you might as while buy brand new Tokicos.
Old May 20, 2011 | 11:58 PM
  #3925
xxxxxxxxxx's Avatar
i broke a bolt that holds my rear camber kit can i just buy one at the hardware store, the same size or is it like a special bolt
Old May 21, 2011 | 12:10 AM
  #3926
3truman's Avatar
Most hardware stores carry the same if not better quality hardware then what you were given to put on said item. I needed a bolt for one of my ART pipes and I got a stronger bolt from the auto parts store. If you have part of the bolt(head is best) just bring it in to them, show them and they will help you
Last edited by 3truman; May 21, 2011 at 12:14 AM. Reason: spelling and add more info
Old May 21, 2011 | 12:33 AM
  #3927
Mr.202?
someone on a nother thread mentioned this, you need to make sure the bolt you are going to buy has some hardness rating, the cheap bolts at homedepot aren't hardened or what not and are just cheap steel with some tin coating.
Old May 21, 2011 | 12:46 AM
  #3928
xxxxxxxxxx's Avatar
i need to get the one that goes here. i have the other one off , i should take that one right.
Old May 21, 2011 | 12:53 AM
  #3929
3truman's Avatar
Yes, to a serious straight up hardware store, like previously stated not Home Depot or lowes, if you have that bolt, and a good knowledge of bolts, they can look at the head and get you the same thing or something stronger/harder
Old May 21, 2011 | 02:00 AM
  #3930
MannyFresh's Avatar
On the 03 sedans are the turn signals suppose to be on when headlights are on?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
