Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jun 2, 2011 | 08:57 PM
  #4066
ilv2xlr8's Avatar
Is it okay to debadge the G35x emblem if the bumper has been recently painted? (1 1/2 months ago)
Old Jun 2, 2011 | 09:16 PM
  #4067
MannyFresh's Avatar
Where can I find a grill that is just like the stock one but without the emblem?
Old Jun 2, 2011 | 09:24 PM
  #4068
SN00P's Avatar
CLUB MODERATOR
ionic is making them for us now or you can DIY .. one or the other :-)
Old Jun 2, 2011 | 10:54 PM
  #4069
naughty240's Avatar
its a gamble. I have done cars and seen the emblem pull of paint. Especially when the emblem was put on when it was fresh.
Old Jun 2, 2011 | 11:00 PM
  #4070
naughty240's Avatar
Debating black or brown painted engine bay. If I go black I can paint a bunch of stuff brown without having too much brown. I like the idea of brown plenum, TB, strut bar braces, etc.
Old Jun 2, 2011 | 11:24 PM
  #4071
CG4DR's Avatar
JDM visor peoples... were they easy to put in? any tips?
Old Jun 2, 2011 | 11:30 PM
  #4072
SN00P's Avatar
CLUB MODERATOR
PM JDM_cain . he has them on his sedan
Old Jun 2, 2011 | 11:38 PM
  #4073
NFSP G35's Avatar
? = 2B || !2B
^Both colors would coexist nicely IMO.
Old Jun 3, 2011 | 09:10 AM
  #4074
robbiedigital's Avatar
Guys, I'm hoping for a very high-level diagnosis, or possible diagnosis based on the following, terrible description:
At speeds about 70/80kmph, when I turn the car right, I hear a faint grinding/rubbing/buzzing/droning type noise coming from the front left tire. It's getting progressively louder, though the vibration isn't necessarily coming through the steering wheel.
Any ideas as to what this could be? Bearings?
Old Jun 3, 2011 | 09:11 AM
  #4075
Old Jun 3, 2011 | 10:00 AM
  #4076
CG4DR's Avatar
Bearing
Old Jun 3, 2011 | 10:30 AM
  #4077
Any idea how to determine if this is a bearing only or the hub as well?
Mechanic is quoting me about $320 for hub and bearing + install...but I notice the bearing itself is only about $50 from the US
Old Jun 3, 2011 | 01:15 PM
  #4078
ilv2xlr8's Avatar
Thanks. I was about to do it then I thought it wouldn't be a good idea. How long should I wait? BTW, your car looks so sick. Too bad they don't offer that color as OEM.
Old Jun 3, 2011 | 06:24 PM
  #4079
CG4DR's Avatar
hub bearing, 1 thing...
Old Jun 3, 2011 | 09:40 PM
  #4080
G35Papa's Avatar
One way, depending on how bad the bearing is worn, you can jack your car up on one side, leaving the wheel bolted on, grab the top and bottom of the tire and attempt to wiggle the wheel/tire. If there is play, there is a bad bearing. This is more noticeable on the rear than the front. My fronts got loud, humming at higher speeds before I replaced them.
The front is only sold as a complete assembly, hub and bearing. The rear you can purchase the bearing only and hub seperately. If you purchase the bearing alone, you need to have the old one pressed off and the new one pressed back in by your mechanic.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
