Random Little Question Thread
alright thanks, just ordered these for my turn signals http://www.buyheadlightbulbs.com/Xen...p/xc-7440w.htm
trying to get everything ordered to finish off my quad set up
holes already drilled for halos to be mounted behind shrouds
Covers are generally not recommended because with our soft paint if the least little bit of dirt gets under them you'll scratch the hell out of your ride. If you're dead set on getting one PM Gary C, he knows of a good brand.
Hey all, I need to replace a couple of the bolts that came with my Ichiba 5mm V1 wheel spacers. Ichiba wants $25 for a replacement set of 5 which is highway robbery since the originals are a POS. I'm going to go to a specialty hardware store to see if I can find the correct bolts, but wanted to check to see if anyone knew the thread pitch and other specs of these before I took one to the store.
BTW these are the 4th Ichiba part I've purchased and put on the ride and all 4 have crapped out in one way or another.
I will never buy another thing from Ichiba again, never.
^ Studs are 12x1.25 with a 14mm knurl. I'm almost 100% on the knurl size. I'll find out in a couple days cause just ordered some new studs =)
No I'm only running a set on the bottom and some turn signals up top
From searching i found that there is 2 differant window visors / guards availiable for the sedan. But how do they attach? I believe there is the "JDM" ones and a company makes another set.
How do they attach ? Clip on? double sided tape?
