Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jul 20, 2011 | 10:17 PM
  #4501
NFSP G35's Avatar
? = 2B || !2B
^Aren't there like 4-5 places the undershroud bolts along there? You don't really need all of them... actually, if you end up getting an aluminum one, you can totally get buy with just bolting it in two places
Old Jul 20, 2011 | 10:36 PM
  #4502
ccc123pm's Avatar
X
there are 4 bolts along the back side.... one of tabs on the plastic broke, and now I have a sheared off bolt on a second... rocking two bolts on the plastic undershroud!
Old Jul 20, 2011 | 10:50 PM
  #4503
NFSP G35's Avatar
? = 2B || !2B
^oh ok.... yeah, only two with plastic might be a bad idea... :/
Maybe a reverse thread bit? You can get drill bits that are cut in the other direction, you put them in the drill, and set it to turn the wrong way (which is actually the right way because the bit is cut backwards)
It will start drilling a hole in the bolt, but if it just happens to catch or snag or anything (as a drill bit often does) it will usually unscrew the bolt. If not, once you have a hole drilled in it, you can then use an actual bolt extractor, which also kinda looks sorta like a bit, only it's actually designed to snag/grip into the drilled hole.
Old Jul 20, 2011 | 10:57 PM
  #4504
ccc123pm's Avatar
X
^tried both.... open to ideas
Old Jul 20, 2011 | 10:58 PM
  #4505
NFSP G35's Avatar
? = 2B || !2B
^Hmmm.... have you tried procuring a paddle? It appears you may be up the creek without one
Old Jul 20, 2011 | 11:07 PM
  #4506
ccc123pm's Avatar
X
ha, I could make a paddle..... in the meantime, http://www.asashop.org/autoinc/may2003/techtotech.htm
Old Jul 22, 2011 | 08:45 PM
  #4507
VincenzG35's Avatar
I was thinking of getting the strafe hood for sedans with the vents like SD genius has do you guys reccomend it? The material its made of how will it last through the seasons? Is there any protection under the vents to stop moisture/rain/snow from reaching the engine
Old Jul 23, 2011 | 02:31 PM
  #4508
GreenPenguin's Avatar
05 G Sedan 6MT. Hearing a "thump"/"click" when I turn my steering wheel. I'll back out a space, stop, put it in 1st, turn the wheel in the opposite direction, then I get the "thump/click". I think I heard it for the first time on Thursday. The last mod I did was the tokico dspec and stech mod 2 months ago.
Any ideas?
Old Jul 23, 2011 | 09:32 PM
  #4509
NFSP G35's Avatar
? = 2B || !2B
Is our IAT built into the MAF? Or elsewhere?
Also, has anyone ever lengthened the wires on the MAF?
Old Jul 26, 2011 | 08:22 PM
  #4510
thescreensavers's Avatar
Mr.202?
Looks like I will be visiting my dealer soon, and yes thats the infamous #6
Old Jul 26, 2011 | 09:49 PM
  #4511
ronniepetras's Avatar
What's wrong with it?
Old Jul 26, 2011 | 10:00 PM
  #4512
NFSP G35's Avatar
? = 2B || !2B
Hey! Looks just like mine did!
Old Jul 26, 2011 | 10:35 PM
  #4513
Mr.202?
The oil is not suppose to be there
https://g35driver.com/forums/engine-...rranty-up.html
lol, then yours wasnt too bad, some people have it almost filled to teh brim with oil!
Old Jul 27, 2011 | 12:51 AM
  #4514
Thanks for the info Andre, I changed my spark plugs 2months ago but I never noticed any oil in any of them so I guess I'm lucky, I'm at 100k as of now
Old Jul 27, 2011 | 01:41 AM
  #4515
Trickstyle's Avatar
sooo say i do have oil when i change my plugs, i can just clean it out right? I dont see the problem here... does an O ring need to be replaced?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
