Random Little Question Thread
Old Oct 27, 2011 | 01:22 AM
  #5041
Shanes_G's Avatar
the guy at auto zone said there all oxygen codes
Old Oct 27, 2011 | 06:56 AM
  #5042
TurTLe*'s Avatar
get the Pxxxx code not what the guy says.
a spacer and intake mod will not effect o2 sensors. exhaust mods will. Either your sensor just happen to crap out at the same time you did those mods or the guy doesn't know what he is reading
Old Oct 27, 2011 | 12:20 PM
  #5043
g35_white's Avatar
At freeway speeds, there is lots of wind noise coming from right passenger side area. Around the rear right 3/4th area. It is disturbing and surprising since it is coming from rear part of car. Is it common? What could be the problem?
Old Oct 27, 2011 | 12:30 PM
  #5044
TORETTO's Avatar
open window???!
Old Oct 27, 2011 | 03:04 PM
  #5045
g35_white's Avatar
Originally Posted by STAP IT
open window???!
no sir, no open windows, no open doors. it's coming from day one since i owned it.
i noticed that the rubber beading that is between door and body is a little out of line. could it be the reason?
Old Oct 27, 2011 | 10:37 PM
  #5046
Matzo Ball's Avatar
will close ended Muteki 34mm lugs fit properly on Ichiba extended studs w/o spacers?
Old Oct 28, 2011 | 07:13 AM
  #5047
ImIn06GT's Avatar
i have that thing too, just started recently, i think its that rubber thing that goes around the door
then again i always listen to music, so that doesnt bother me
Old Oct 28, 2011 | 03:59 PM
  #5048
JaE35's Avatar
Moderator
G35 Sedan
Needs some help fellas, i've picked up some oem brembos for my sedan...just wondering what brake lines you guys think i should pick up, don't wanna put the factory ones on and also what bolts in particular i need for the rears, from what i understand I can use my existing oem front ones and just need to replace the back 4
Old Oct 28, 2011 | 05:18 PM
  #5049
CG4DR's Avatar
extended how much?
Old Oct 28, 2011 | 05:19 PM
  #5050
CG4DR's Avatar
i'd use some steel braided lines. and not sure about the bolts
Old Oct 28, 2011 | 05:48 PM
  #5051
Matzo Ball's Avatar
Originally Posted by Mr.BalloonHands
extended how much?
standard extended studs that come with their V1s.
Old Oct 29, 2011 | 09:13 PM
  #5052
Wilg35j's Avatar
Anybody know what size are the map and dome lights, i bought led's and i got 36mm ones but they dont fit???
Old Oct 29, 2011 | 10:33 PM
  #5053
VincenzG35's Avatar
Wil shoot me ur cell so you can just txt these things there 31 mm and the doors are 29 and when they say 29 they mean it I squeezed my 31s and it was a pia so stick to what they say just easier
Old Oct 30, 2011 | 09:57 AM
  #5054
CG4DR's Avatar
I would probably say no. I'd go with open ended sr35s
Old Oct 31, 2011 | 04:30 PM
  #5055
g35_white's Avatar
Is the ride so harsh on G35 with sport suspension that you feel everything on freeway speeds or is my suspension going out?
I did a 300 mile trip and it was very bumpy and could literally feel each and every thing that was transmitted from road. Is it normal?
One thing i have noticed is, at 70 mph, passenger seat vibrates a lot. And lots of undulations of road are felt. I had passengers in back seat and they were complaining of bumpiness and bad ride quality. Is it normal?
OTOH, I do love the way it handles curve at 40-50mph.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
