Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 1, 2011 | 07:13 PM
  #5191
g35_white's Avatar
Originally Posted by The X Factor
I tend to hear it more when it's colder. I bought my car in July last year and I didn't notice this sound until winter set in. It seemed to go away, but I'm hearing it again as the temperature is dropping this year.
It is the same thing what i experienced. Didn't happen when i bought it in august this year. Just start to cool down here and it is now making this noise. could be that it is weather dependent.
I never seen this happen in my friend's g35 though. his is a 2006.
Old Dec 2, 2011 | 12:19 PM
  #5192
g35_white's Avatar
Does it happen only once you start early morning or is it every time you drive?
i noticed yesterday that each time i took a parked my vehicle and come back after finishing work, it will make noise. Is it same with you? I stopped like 5 times each for 10-15 minutes and every time it made the noise. is it ok or something is wrong? should it happen only first time in the day?
Old Dec 2, 2011 | 12:55 PM
  #5193
DR.D69's Avatar
Originally Posted by g35_white
Thank you very much.
This is perfectly how it sounds like. But, this didn't use to come before. it just started a couple of weeks back. Why would that happen. Is it pronounced in winters and not in summer?
Maybe you just didnt hear it...it always makes the sound regardless of time of year, However maybe in the winter its a little more pronounced, maybe. But now that your listening for the sound its going to sound louder anyways.
Old Dec 2, 2011 | 02:25 PM
  #5194
The X Factor's Avatar
I hear it more when the car is cold. It definitely still makes the noise all the time, but it's kinda hard to hear in my car when everything is warmed up. I can hear it more when the temperatures are around or below freezing. And it should happen every time you start your car. The ABS has to re-prime itself on start-up.
Old Dec 2, 2011 | 02:29 PM
  #5195
Shift ***** are completely interchangeable, correct? Hypothetically, let's say I wanna trade my shift **** with wood trim for a shift know with aluminum trim. Both should connect and operate perfectly? Is 03 different from 04? Was it 2003.0 that had the button on the side, or does 2003.5 have that, too? Or are any of those different from 05-06? Thinking of switching the trim, and I wanna make sure I trade for the right piece.
Old Dec 2, 2011 | 02:37 PM
  #5196
Wannabe6MT's Avatar
-MN G Crew-
I believe 03.5 got the button on the side. 05-06 has a different color interior though, so your willow won't match with a wheat.
Have you checked ebay? I think the shift ***** are fairly cheap.
Old Dec 2, 2011 | 02:39 PM
  #5197
Songle6MT's Avatar
^Pretty sure 05-06 was a complete redesign, whether or not they will fit in an 03-04 Idk, but it would look way weird
Old Dec 2, 2011 | 02:55 PM
  #5198
Not yet. I just know there's a lot of different types, so I popped a random question here so I know exactly what to look for.
Old Dec 2, 2011 | 07:37 PM
  #5199
NFSP G35's Avatar
? = 2B || !2B
My 03.0 has a button on the side
Old Dec 5, 2011 | 01:39 PM
  #5200
g35_white's Avatar
a very popular mechanic here told me g35 spark plugs are good till 120k miles and no need to change them. i am approaching 100k miles so i was wondering if i should get it changed or should stay put till 120k? please advice.
thank you
Old Dec 5, 2011 | 02:31 PM
  #5201
I just changed mine. They were original and had 106k on them. They honestly weren't that bad, but it's still a really good idea to change them out. It's not very expensive and can make your car run a little better.
Old Dec 5, 2011 | 02:39 PM
  #5202
Songle6MT's Avatar
thank you
Personally I would change mine at 100k if my car had that many miles on it. 120k is a little much. I just like the piece of mind though so to each their own. I'm tempted when I do a plenum in the spring to do plugs as well, the car will probably have 68k on it by then....
Just make sure when you do them not to mix up the 4 and 6 coil pack connections
Old Dec 5, 2011 | 03:05 PM
  #5203
g35_white's Avatar
Thank you. Guess i will get it changed.
@Songle - I won't be doing it myself, hope the shop doesn't screw it.
which spark plugs do you recommend? Stock ones or something better?
Thank you
Old Dec 5, 2011 | 03:40 PM
  #5204
Songle6MT's Avatar
Thank you
I would do NGK plugs. That is what myself and many others would recommend. I'm fairly certain you want the Iridium plugs as well IIRC.
It isn't really that hard of an install but I'm more of a do it yourself person. It could get a little daunting if you didn't want to do it.
Old Dec 5, 2011 | 04:00 PM
  #5205
g35_white's Avatar
Thank you. I will get the NGK Iridium IX LFR5AIX-11.
I saw a video on how to change it and it was quite over whelming for me since i am not a DIY guy and won't like to play with engine. So i may have to pay and get it outside.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
