Random Little Question Thread
Old Dec 7, 2011 | 06:53 PM
  #5236
NFSP G35's Avatar
? = 2B || !2B
^Odd... I'm 99% sure they're on the same fuse.
Is it a wiring/corrosion issue?
Old Dec 7, 2011 | 11:02 PM
  #5237
tylerxfire's Avatar
all figured out..the bulb in the headlight was just blown and the ground wire for the marker was sliced in half, had to cut the wire loom back a little bit and trace it and found that, soldered it back together, taped everything back up and good to go..all bulbs fixed..I beleive i will do that mod to make the marker blink that is odd that it doesnt, seems like a safety issue..
thanks
Old Dec 8, 2011 | 12:20 AM
  #5238
CG4DR's Avatar
definitely helps to have. i like it with my bump style markers. sticks out a little so oncomers can see it
Old Dec 8, 2011 | 02:03 AM
  #5239
Herbbie Hablib's Avatar
I just picked up a set of Hotchkis sway bars for my 06 sedan 6mt, im running full stiff upfront and middle hole on the rear, how is this setup? what are you guys running and why? It feels good on the test drive but havent pushed it too hard yet.
Old Dec 8, 2011 | 03:48 PM
  #5240
Songle6MT's Avatar
Im pretty sure most people like either a softer setting up front than the rear or both equal. Like MED/MED
Here is a sway bar thread. It's a pretty good read, I read through it last night.
https://g35driver.com/forums/brakes-...r-summary.html
Old Dec 8, 2011 | 11:44 PM
  #5241
VincenzG35's Avatar
can someone help me find the best price for struts on my 2003 sedan oem sport tuned suspension I keep getting confused with the regular ones
Old Dec 11, 2011 | 04:04 PM
  #5242
Max626's Avatar
What size extension is needed to run a 350z mid pipe on a sedan, also what sites sell them
Old Dec 11, 2011 | 10:09 PM
  #5243
CG4DR's Avatar
8'' and mynismo.com
Old Dec 11, 2011 | 10:21 PM
  #5244
thescreensavers's Avatar
Mr.202?
^ Wrong its 6"
Just get an exhaust shop to do it for you
Old Dec 11, 2011 | 10:33 PM
  #5245
CG4DR's Avatar
same thing
Old Dec 11, 2011 | 11:25 PM
  #5246
NFSP G35's Avatar
? = 2B || !2B
^Exactly.
Apart from the 2" difference, it's pretty much exactly the same thing.
Although, the 03/04 non-nismo and 05/06 have significantly different needs as far as exhaust length goes.
It wouldn't surprise me if a 6" worked better on an 03/04 and an 8" worked better on an 05/06
Old Dec 12, 2011 | 12:16 AM
  #5247
CandlestickPark's Avatar
ill Sedan
^Exactly.
Really? The Y-pipe and middys are the exact same length since they are the same and interchangeable respectively. Are the OEM mufflers different lengths?
Old Dec 12, 2011 | 12:20 AM
  #5248
sauminator's Avatar
What needs to be done in order to place a 05+ g35 coupe auto transmission in my 03 coupe?
Old Dec 12, 2011 | 12:21 AM
  #5249
NFSP G35's Avatar
? = 2B || !2B
^Yeah.
Or at-least the tips are different.
My 03/04 was fine when I had the stock bumper, but they were hellatucked on the 05/06, but the Borla (which came off an 05) sits absolutely perfect.
If I still had the 03/04 bumper with no Nismo lip, it would poke out and look funny.
Not to shoot you down... but give up on that idea. It'll be a crapload of work.
They changed the transmission computer completely around 04.5, and I seriously doubt the 03 ECU would jive with it, especially if it's the really old gray connector ECU.
Old Dec 12, 2011 | 12:27 AM
  #5250
sauminator's Avatar
They changed the transmission computer completely around 04.5, and I seriously doubt the 03 ECU would jive with it, especially if it's the really old gray connector ECU.[/QUOTE]
I had a local shop say they could order me a newer transmission and all they would have to do is change the control module out or somethin. I have been some-what sketchy on the idea...thanks for the reply!!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
