Random Little Question Thread
Old Jan 8, 2012 | 07:23 PM
  #5356
ronniepetras's Avatar
Originally Posted by Wilg35j
What do i have to do, to make my 03 AT sedan vlsd, what differentials can i get and are they dorect swaps?
Here you go
https://g35driver.com/forums/showthread.php?t=320425
Old Jan 8, 2012 | 07:24 PM
  #5357
NjMatteSedan's Avatar
Originally Posted by NFSP G35
^Do you check your oil between changes???
No, i just go at around the mileage it says on the sticker they put for the next service
Originally Posted by TurTLe*
that is the oil PRESSURE light.
Replace the oil pressure sensor, its normally a $10 part. Make sure oil is full ( stupid dipsticks are hard to read). If your full on oil, replace the sensor. If you still have the oil light, then you have a serious problem!
Oil pressure lights dont kick on unless you are really low in oil, like 1qt only in the system. But its more common that sensors fail. I just replaced one on the GF's car not to long ago, cost me about $7-8. Large 24-26mm wrench. I know for the VQ30's the sensor is right by the oil filter. Most likely same for the VQ35.
about your yellow light, LOL lucky guess on washer fluid. Just fill it up and see if that goes away. I wouldn;t know if we had a washer fluid light, i always fill it every oil change and rarely use it.
where can i get the sensor?
Old Jan 8, 2012 | 07:40 PM
  #5358
NFSP G35's Avatar
? = 2B || !2B
Good lord man check your oil! Just make sure the car has been sitting on level ground without running for at least an hour so you get an accurate reading
Old Jan 8, 2012 | 07:42 PM
  #5359
will do
Old Jan 9, 2012 | 11:29 AM
  #5360
jdubin94's Avatar
Small question.
On my ac controls, is it normal that I cannot turn off my air circulation button? It is always on. When I push it in.. the little light won't go off.
Old Jan 9, 2012 | 03:10 PM
  #5361
CG4DR's Avatar
push the outside air button and it'll go off
Old Jan 9, 2012 | 03:15 PM
  #5362
CG4DR's Avatar
Is the newer 3.7 Diff. VLSD?
Old Jan 9, 2012 | 03:19 PM
  #5363
TurTLe*'s Avatar
rockauto has them from $7-13
wow @ the only looking at the sticker thing but it doesn't surprise me at all. +80% people i know dont bother checking oil levels or even tire pressures every couple of months. They just drive the car, its more and more common now. Especially higher end cars, most owners dont care/ have time to check. They are lease cars or only 5 year cars until they sell so they dont care.
Reminds of the whole BMW maintenance free for 3 years, poor girl though it means you didn't need to bring it for for 3 years. So 40k on the ORGINAL oil and filter.
Old Jan 9, 2012 | 03:21 PM
  #5364
CG4DR's Avatar
wow @ the only looking at the sticker thing but it doesn't surprise me at all. +80% i know dont bother checking oil levels or even tire pressures every couple of months. They just drive the car, its more and more common now. Especially higher end cars, most owners dont care/ have time to check. They are lease cars or only 5 year cars until they sell so they dont care.
I see it happen all the time at my work.
Old Jan 9, 2012 | 03:51 PM
  #5365
Yes
Old Jan 9, 2012 | 04:05 PM
  #5366
CG4DR's Avatar
Originally Posted by ronniepetras
Yes
Interesting. I may have to pick one up since I can only find the ring and pinion for the 3.9.
Old Jan 9, 2012 | 07:57 PM
  #5367
NFSP G35's Avatar
? = 2B || !2B
^IIRC there's something extra you have to change to get the 3.7 to work, like maybe ABS wheel-speed sensors or something??? IDK, but if you ping G35Papa, he can probably tell you.
Old Jan 9, 2012 | 08:21 PM
  #5368
wow lol was she a blonde?, how did that engine not blow up haha
Old Jan 9, 2012 | 11:14 PM
  #5369
CG4DR's Avatar
or i could message that guy that has one on his car that Marcus did a photoshoot with.
Old Jan 9, 2012 | 11:40 PM
  #5370
thescreensavers's Avatar
Mr.202?
https://g35driver.com/forums/drivetr...tial-swap.html
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
