Random Little Question Thread
Old Nov 23, 2012 | 01:03 AM
  #7771
thescreensavers's Avatar
Mr.202?
Originally Posted by Airic214
do you have this setup ? if you do how is it?
pros and cons?
I had revised Zs on sport 18s, it was more than fine.
Old Nov 23, 2012 | 05:05 AM
  #7772
Airic214's Avatar
will z springs put stress on my car? because im just getting the springs nothing else
Old Nov 23, 2012 | 09:36 PM
  #7773
Marioh's Avatar
Looking for recent sellers for the M3 lip. It seems like the 1170 is the way to go, but most of these threads with eBay links are 3+ years old.
If anyone has information/links/recommendations that is recent that would be super rad.
Old Nov 24, 2012 | 01:38 AM
  #7774
Airic214's Avatar
is there a DIY on installing shift boot for an 2004 g35 sedan automatic?
Old Nov 24, 2012 | 06:53 AM
  #7775
DVG's Avatar
DVG
Nismo Z + OEM 19s FTMFW My ride isnt harsh enough for me to care, maybe its a bit firmer but I dont care in the slightest.
If your springs dont match the spring rate your damper was designed for, it will cause accelerated wear on the damper. I saw a post somewhere that showed all of the spring rates for g35s and 350z and different trims/years of both.
Old Nov 24, 2012 | 06:32 PM
  #7776
Airic214's Avatar
has anyone painted their oem rays white? any pics ?
Old Nov 24, 2012 | 08:49 PM
  #7777
dominate's Avatar
I'm going to buy the Ionic nismo rear lip, could anyone chime in on fitment? Right now with the sale, the painted option is less than $100 more. If there is zero work needing to be done then I'm leaning toward buying it painted from them. Also, any install guides? Thanks
Old Nov 24, 2012 | 09:07 PM
  #7778
Muney2bmade's Avatar
Amazon Amazon
Anyone know what I would have to do / if its possible to fit these ?
06 base coupe btw
Probably too wide lol, do they have any replicas for the G35 like that.
Old Nov 25, 2012 | 01:13 AM
  #7779
Mr.202?
Originally Posted by g35_white
Is it ok if we use Manual mode to shift till 5th gear then switch it to Drive mode at around 50-60mph in order to lower the rpm at freeway speeds?
Is it ok to use Fuel System cleaner with a 2005 g35 or could it damage the fuel lines?
thanks
Your RPM should not change at all by switching from 5th to Drive.
In Drive the Torque converter locks earlier so once you are cruising its best to put it into Drive.
Most Fuel System Cleaners are Junk, the ones that work contain PEA. Techeron, Redline Si-1 are some of the few that have it. Which you can get OTC.
It will only make the shocks work harder, so they will go bad sooner. When no one knows. Just roll with it and if it breaks replace it.
Old Nov 25, 2012 | 03:59 AM
  #7780
j.dmcar's Avatar
03 g35 sedan lip kit? is there any out there?
is there any lip kits for 03 g35 sedan? thanks. or nice body kits?
Old Nov 25, 2012 | 04:45 AM
  #7781
mysoda's Avatar
i have a nismo rear lip if you want. i am from bayarea as well.
Old Nov 25, 2012 | 01:01 PM
  #7782
19kdrill's Avatar
Lip kit for the front or rear?
Old Nov 28, 2012 | 10:54 AM
  #7783
DVG's Avatar
DVG
Working on coupe seats... the price is acceptable to me but the seller wants to meet in person and do cash. I want to confirm they are working, so I offered to meet in person and then transfer via paypal, so I have some protection in case they are not functioning. He said no, because he has been robbed through paypal before (???).
So my other option is test all functions manually, meaning I need a pinout. I asked him what year, if it has memory, etc. He said it is an 04 with memory, heated seats, electronic adjustment.
IIRC, 04 = no memory. So, I ask you, g35drivers, what is your impression of this guy? IF I am right about that, what is a likely explanation for the inconsistency?
Old Nov 28, 2012 | 01:03 PM
  #7784
TunerMax's Avatar
G35
I'd walk away if he won't do paypal. I've had one guy say that, smoking deal on an item, once he said he doesnt do paypal he cited the same reason, I walked.
Just my personal opinion. I try not to buy anything that I cant use PayPal on
Old Nov 28, 2012 | 01:08 PM
  #7785
herrschaft's Avatar
Just go do the transaction in person. When I want to buy something thats within an hours drive, I prefer to meet face to face as well.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
