Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Nov 13, 2012 | 10:45 PM
  #7726
NFSP G35's Avatar
? = 2B || !2B
Yeah, the tube that it goes in sits really close to the block and the little plate thingy on top kinda makes it look strange.
This thread should help: https://g35driver.com/forums/picture...post-here.html
Old Nov 14, 2012 | 11:01 AM
  #7727
Texas-G's Avatar
yeai was looking at that thread however i saw alot of them coming up above the engine which is what raised my question
Old Nov 18, 2012 | 08:09 PM
  #7728
Airic214's Avatar
Headlights
Does anyone know how to clean headlights good? because mines is a a little yellow i tried that turtle wax stuff with the sand paper. it helped but just a little. i want it to be clear anyone know how to do this?
Old Nov 18, 2012 | 09:43 PM
  #7729
Texas-G's Avatar
i sanded mine with 1000 grit sand paper, wetsand, then re cleared them did the job
Old Nov 18, 2012 | 09:57 PM
  #7730
Airic214's Avatar
do you have a before and after pic?
Old Nov 18, 2012 | 10:06 PM
  #7731
Roh's Avatar
Roh
hey guys, so we have a 07 rwd g35 sedan at home and a 04rwd g35 sedan, would my winter tire setup from the 04 fit on the 07, running oem wheels from the 04 wrapped in winter tires. i dont think it will but thought i'd double check. cuz if it did i would be able to store the 04 away for the winter.
thanks.
Old Nov 18, 2012 | 10:07 PM
  #7732
Texas-G's Avatar
havent taken a after pic but ill try and snap one for you tomorrow.
Old Nov 18, 2012 | 10:11 PM
  #7733
Songle6MT's Avatar
thanks.
They should fit fine....
My roommate has 04 g35 (non-sport) wheels on his 08 g35 6mt sedan.
Just make sure you have the correct style lug nuts.
Old Nov 19, 2012 | 12:01 AM
  #7734
DVG's Avatar
DVG
thanks.
Im assuming that the brakes will clear, unless he has akebonos or something. I dont know when they started using those. only other important things are total diameter and offsets http://www.1010tires.com/WheelOffsetCalculator.asp
Old Nov 19, 2012 | 12:27 AM
  #7735
TunerMax's Avatar
G35
And tpms
Old Nov 19, 2012 | 12:41 AM
  #7736
DVG's Avatar
DVG
I didnt really think those were a necessity, just a light would be on without them.
Old Nov 19, 2012 | 08:41 PM
  #7737
Ramiel's Avatar
So today I jacked up my sedan ('05 AT, sport pkg) to change the oil for the first time since I bought it, and noticed that the front driver side strut doesn't match the others. It is black while the other three are red. The red ones are Nissan badged Tokicos and I am assuming they are standard equipment with the sport package. I'm not sure what the black one is, perhaps an OEM part, I tried googling up the numbers on it and came up with nothing. Not sure which of the previous owners (or their mechanics) pulled this stunt, but basically I'm wondering if these struts have the same specs, or should I shop around for a new one to match the others. I've attached the best pic I could get of the info on the oddball strut.
I'm also wondering if the springs might be different types. It's dark out now, but tomorrow I might go out and take a better look at them.
Note: Recently brought the car in to Riverside for some other work, and they their basic vehicle inspection and didn't notice anything regarding the suspension, even though they checked the tire wear. Curious.
Old Nov 19, 2012 | 08:50 PM
  #7738
04nismoG's Avatar
I also have a sedan with the sport package and had to get a new strut and the one napa gave me was black and since I was curious about the difference between the two I ask them for a strut for a 350Z and they brought me the same strut with the same part number.
Old Nov 19, 2012 | 08:56 PM
  #7739
Ramiel's Avatar
Yeah, weird. Maybe I'll look through the old service records and see if I can find anything
Old Nov 19, 2012 | 09:05 PM
  #7740
DVG's Avatar
DVG
You should definitely research that, its possible that it has the specs of a non sport.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
