Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 3, 2013 | 12:48 AM
  #8521
JDMswagSerf's Avatar
Originally Posted by thegreatkwijibo
Yes but they'll provide more of a drop than sedan springs, and if you don't upgrade your shocks they will wear out.
than sedan springs? or coupe?
what are some good I'm expensive shocks that will allow good comfort with the springs?
Old Feb 3, 2013 | 01:16 AM
  #8522
thegreatkwijibo's Avatar
well lowering and good comfort don't really go together. most people run tokico d specs when they go really low on springs but they aren't really cheap. z struts should work plenty good though.
Old Feb 3, 2013 | 02:02 AM
  #8523
well lowering and good comfort don't really go together. most people run tokicos when they go really low on springs but they aren't really cheap. z struts should work plenty good though.
yea. I realized this with myIntegra.
so some 03 350z shocks eh?
I'll just buy some new 350 shocks then in a few weeks.
Old Feb 3, 2013 | 02:04 AM
  #8524
you guys think this wing will look good on my sedan?
http://inlandempire.craigslist.org/pts/3505830619.html
it looks sweet on the Guys coupe from the side.
it's on my way to pick up the tiens.
I'm trying to trade him things I have. maybe 20$ on top of what I trade. but yea. I'll probably stop and test fit it.
just confirmed. straight trade for an hid kit and some amps I haven't used in 3 years.
if I don't like it I can re sell it or something.
Old Feb 3, 2013 | 02:31 AM
  #8525
dominate's Avatar
^ If you're going for a medium sized spoiler I'd go with OEM.
Old Feb 3, 2013 | 09:14 AM
  #8526
TunerMax's Avatar
G35
There are plenty of lowering setups that offer as good as stock ride quality.
Tokicos are the stock shock used on the sport edition of the G. If you get the 350z socks they should be tokicos right from factory.
Old Feb 3, 2013 | 11:49 AM
  #8527
dj714's Avatar
Any specific Z springs/shocks to look out for?
Old Feb 3, 2013 | 01:40 PM
  #8528
TunerMax's Avatar
G35
I can't answer that one, but the answers are out there, easy to find, and someone else here might be able to help better.
I just did it properly from the start and got coilovers.
Old Feb 3, 2013 | 02:11 PM
  #8529
Originally Posted by jhern1016
Pretty much anything that fits the 350z will also fit the g35 coupe or sedan
okay thanks.
so the 350z shocks and 350z tiens should give me close to stock ride comfort is what you're saying?
Old Feb 3, 2013 | 02:56 PM
  #8530
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Which spring are you getting?
OEM Springs
G35 sedan with non sport suspension (Black Shock/Struts)
Front: 283 Rear: 308
Tein H-tech 350z (GOLD, Linear springs, 1.4”/1.3” drop on G35 Sedan)
Spring rates in lbs. 358/375
Tein S-tech 350z (GREEN, Fronts are progressive, Rears are linear) 1.7”/1.6” drop on G35 sedan
Spring rates in lbs. 386/402 (Front initial rate is 327 lbs.)
Old Feb 3, 2013 | 04:44 PM
  #8531
catchair23's Avatar
light upgrade
I just purchased an 05 Coupe, and feel the low beams, while bright white, aren't as good as they could be. Additionally, the high beams (yellowish), while adequate could also be better. What is the simplest way to improve the lighting? Cost is not a large factor.
Old Feb 3, 2013 | 04:59 PM
  #8532
TunerMax's Avatar
G35
okay thanks.
I already posted that the teins were fairly well known to be harsh.
If you want to know more than the simple will it fit questions with suspension, you have a ton of research ahead of you, there are literally tons of options and all have pros and cons
Old Feb 3, 2013 | 05:02 PM
  #8533
TunerMax's Avatar
G35
Catchair - projector retro fit, not simple, but that is what you want, it will cost around 800-1500 depending on what you want
Old Feb 3, 2013 | 05:52 PM
  #8534
just picked them up.
they're the green tiens.
he said they were on his 08 350z.
Old Feb 4, 2013 | 01:16 AM
  #8535
haha had a brain fart and forgot to put D spec
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
